Mack869
Everything posted by Mack869
  1. Beautiful work. Are you looking to sell something like this? Also, BUYLEATHERONLINE.COM has nice, thin finished goatskin that I've gotten in the past. (Having said that, the only colors at the time were black and tan.) The pigskin suggestion by another responder isn't a bad ides. It's pretty tough stuff, so if durability is more important than appearance, I'd go with it. Best of luck with your future projects.
  2. Forgot to mention that this binder was sent to Charles Osgood.
  3. From the album: CBS Sunday Morning
    Response letter from Charles Osgood. Now it's your turn, put the pressure on by asking CBS to do this !
  4. From the album: CBS Sunday Morning
    Weird snap tab but had to make it work and at same time not interfere with logo image on front.
  5. From the album: CBS Sunday Morning
    Trying to get CBS Sunday Morning to do a segment on Leather art, showcasing Stohlman museum in Fort Worth as well as the exceptional work of artists such as Peter Main. Help by contacting CBS and asking for a segment on our art ! Charles Osgood PO Box O 524 West 57 Street New York, New York 10019-2985 212-975-7110 sundays@cbsnews.com
    © be advised that the sun image is almost certainly a trademark or copyrighted image.
  6. Just my $ 0.02 but I made an edge slicker for my dremel using the screw bit attachment and securing a multi-layer disk of leather with that set screw. Turned on dremel at lowest setting and used small round dremel stone to shape curve. The disc indentation also gets burnished and it turns out that burnished leather can burnish leather. You can also reduce diameter way down to slow rotation = reduce heat. Must admit that a small piece of wood should work also. Anyway, it works for me. Good luck !
  7. Actually I use a dremel for burnishing edges as well as other applications beyond edging. You can create your own ' attachment' with the generic threaded shaft attachment bit that comes with the dremel. Seems to work fine for me. (Also use sanding sleeves to dress down leather edges). For large projects or burnishing multiple layer items you would want something more "industrial". As an example, I probably would use my dremel for dressing a belt or strap edge, but wouldn't on anything larger ( lack of patience ; - ))
  8. I agree with Barehands and Bob, that looks exactly like a water stain to me. You could try casing the piece first and letting it dry in cool air (would also suggest using distilled water) thoroughly to see if contrast is reduced (wetness needs to be consistent on whole piece, otherwise you might only end up moving the issue to a different location). If that doen't help to your satisfaction, I think your fallback should be dyeing. I have never had good luck with chemical treatments (e.g. oxalic acid etc.). My $0.02, best of luck !
