Hello All,
I'm new to this forum, and would like to seek some help/guidance from other Adler 205-370.
Earlier this year, I purchased one of the last new 205-370 available from Michel Simard in Montreal. From the very beginning, I've had issues with the stitch-length, or should I say the symmetry of the stitch-length in forward vs reverse. I was told it was normal that the machine would not back-stitch in its holes, when adjusting the rotating knob on the lever. To ensure same stitch-length in reverse, I had to (from Michel Simard's perspective) use the metal (chrome) sliders above and below the lever, and set them to a fixed position where the forward and backward stitches would be equal. I purchased Weaver Leather DVD on the Adler 205, and it's very clearly stated that stitch length should be the same in forward and reverse, solely using the knob to adjust it. I also watched many videos on the 205 and clones, and they all backstitch in their holes.
After a few visits, this problem was partially solved. However, now, the machine maximum stitch-length went down to less than 8mm (instead of 10mm) when sewing leather. I was told by Michel Simard to test it on a piece of paper, and if it was 9mm long, it was all right. The spec states 10 mm in forward and 10mm in reverse, and my machine used to reach that length before the last adjustment.
Now, also after the last adjustment, the machine has started to "throw" (for lack of a better word - I'm french-canadian) the leather toward me (the front of the machine) when sewing. The needle and the feed-dog move forward as the presser foot rises. This is possibly one of the reason I loose on my stitch-length. Plus, when sewing in thicker material, it makes the needle break, so I don't want to use my machine anymore.
It is still under the original manufacturer's warranty, so I need to run this through Michel Simard, but every time, I'm told that it's a normal behaviour.
So, I'm reaching out to you, Adler 205 owners, to help me determine if I'm crazy and this is all normal, or if you get completely different behaviours from your own machine.
Also, if anyone of you know a 205-guru that would completely readjust my machine and make it work as it should, I would be very grateful !
Thanks in advance guys !
Best regards from Montreal
Danny
