mcguyver42
Everything posted by mcguyver42
  1. Got it, for German machines the spec is Gudentight for thicker denser materials and lesserso for lighter materials until everything seems to be sewing properly, but always with the minimum tension needed. Well thank you, that gets me moving forward again without wondering that I'm missing something.
  2. Well, that's what they say, but that's about all they say. Of course there is no gauge to measure the pressure being applied to the material, that would be ridiculous, but is there some guidance beyond "tighten until it seems about right"
  3. Well my Adler 67-gk373 is sewing pretty darn well. After much grief to get it to that point, it turns out that I am a hand sewer and looking to sell it. The machine is normally set up for 138 thread and a little heavier material. To get it ready to start showing it, I set it up for 92 thread and was sewing off 2 thickness's of vinyl and noticed that it doesn't thump. I was having trouble hitting the same holes while back stitching, but that could very well be a loose nut behind the wheel because I am no machine sewer. I started putting 2 and 2 together and realized my presser bar tension might be off. I looked through the adjustment manual, (which I was able to get through with all of your generous help). No mention of it, and I don't remember why I had it at the minimum tension setting. I thought it might be a user adjustment, but found the user manual to be lacking. Does anyone know what that knurled knob thingy on top of the double leaf springs is for? Is it a user adjustment? Surely you don't want it to be tighter than it needs to be, because that's a lot of stress on a lot of parts.
  4. Sounds like diluted dye applied with an airbrush might be thriftier too. At $25 - $30 a quart this stuff gets pricey in a hurry. And not all bottles are full by the way, some up to the cap, and some 1 1/2" down the neck. We are talking fluid oz. here, so I don't know? I've seen powdered dyes offered by some suppliers that you mix up with denatured alcohol. Denatured alcohol is out of control now though, mostly methyl alcohol, and who knows what else. Woodworkers don't want to use it in their shellac anymore, and are resorting to Everclear if they can get it. The same applies to us. Between that and the alcohol drying out the leather, it's making me want to take a hard look at water based dyes. Or other ways to dye leather? Any input on that?
  5. I gotta try to design some gusset's now, I better up the cat treats
  6. Update for what it's worth. I'm a beginner so verify anything that I say. For me, I think I found my test to see if my veg tan leather needs to be oiled Find a waste spot on the leather and scratch a short line. It should emboss a line instead of just scratching through the top of the grain. oil if needed without being too heavy handed as Fredk cautions, wait the requisite 24 hours and retest. I did that on the side under discussion, and my knife slices right through in one light to medium effort pass with maybe a fiber or two hanging on.
  7. If I understand Burkhardt, are you saying that you oil leather that is already in good condition before dyeing as a sort of damage control, and then again after? Mine was dry to start with. It sucked the dye right out of the sheep's wool as soon as it touched, I couldn't control it. I used so much light brown dye that it ended up chocolate. But going back to that water thing, I didn't know how much soap to use and didn't want to overdo it, so I just cased it real good with water. You and Chuck both said that the surface tension would be reIeased during normal handling over the course of the build. But, I worked it through folding the edges back gently, and not being overly forceful as you said. I cupped my hand over the interior portions and used my fingers to push up some from the bottom. I could see a pull up effect on the leather when I was doing that and could feel the leather relaxing. lo and behold, it lays nice and flat. I let it dry overnight with a cutting board laying on top of it for good measure. The picture is from the next morning. Problem solved! I'm looking forward to finding a recipe for the oil, dye and water if anyone has one.
  8. FredK also mentioned putting a little hot water in the mix. So if I put say a pint of oil in a pot, how much soap and water? and we are discussing regular dish washing liquid here? I feel that I've oiled this leather enough, and that any more would be too much. Actually it's becoming tan on the back side, and I hope I don't run into any glue stick issues. Still, I wish there was some kind of test, (A moisture meter on wood for example). I compared my dyed and oiled pieces to the untreated portion of the side to try to discern some differences that I could call "tests": examining the cellular structure of the edges with a magnifying glass, trying to note different sounds when rubbing the back side with my fingers and fingernails. I couldn't pinpoint any notable differences. The grain does appear to be thinner and more defined on the oiled pieces, but that could just be the dye. I think the expected weight when you pick up similar sized pieces is a little different. The oiled pieces do make more of a satisfying smack sound when I drop them onto the workbench. A thumbnail impression is definitely more self healing on the non oiled pieces. I know that I'm over analyzing, and should just let experience take it's course, but I bought quite a lot of leather in the beginning. It wasn't top quality to begin with and it's been in storage for 3-4 years. I'm concerned with losing the whole lot of it if I don't learn how to take care of it. When I say storage, I mean in the house under heat and air and out of the light. I'll try all of your suggestions, definitely oil with soap before I cut out and dye the rest of the pieces. At least it reassuring to know the curling is normal, I appreciate the experience and encouragement.
  9. The first backside picture is of the really curled up piece. The other 2 backside pictures and the 2 grain side pictures are from the side that the pieces were cut from. I really appreciate your input. I think the project is a flop at this point. I'll go ahead and build it for the practice, but I shure would like to learn from this. Thanks
  10. It seemed like the leather was reasonably pliable. I just rolled out the rest of the hide on the bench for a look at it. Possibly it may feel a little light for the size but I'm not sure. What does the soap do? I gave it a very heavy oiling with olive oil a few hours after the dye up. The next morning I gave it another very heavy oiling, and then two more heavy oilings. It didn't soak the oil up near as fast on the last oiling or two, and I was able to rub it in circles and even out the blotchy dye job some. Still it came out much darker than the intended light brown, and the pieces are curled. I didn't mention this before because the curling was already very evident, and I didn't want to add variables that may not apply. There were some spots on the leather from the workshop. I tried 3 of the methods that are well agreed upon by members here. (Alcohol, 50/50 lemon juice and water, oxalic acid)
  11. Hello, I've been at leathercraft for a few years now, but I don't have a lot of hands on unfortunately. I'm really struggling with being able to evaluate leather for proper suppleness/ oil content? I am making a briefcase for my son. I selected a 6-7 oz veg tan side from my leather collection. It's a Tandy hide, probably Brazilian grade C, not terrible looking, not been oiled since I have had it. I rolled it out on my bench and had to weight both ends to hold it down while cutting out my pieces. My scratch awl didn't make a very convincing groove or line to follow; it was very shallow, almost like a light cat scratch and I had to look at it from different angles to see my cut lines. I had to make 4 or 5 passes with a reasonably sharp round knife. My knife would get stuck, and I had a few skip offs. I ended up pulling it towards me, and even using it like a strap cutter. My big pieces were still wanting to curl up by an inch or more, even after laying out on the bench for a few days. I had a disaster of a dye up and pretty sure now that I should have oiled my leather. I'm wondering if some of the above should have been clues that this hide needed oil? What do you guys look for when you are evaluating a hide for it's overall condition and usability? Do you have some tests that you make on the leather, or do you just know by feel and sight? How does temper figure in there? Is firm temper leather just dryer leather? Thanks in advance, Guy
  12. If anyone thinks they can use this thing or any parts off of it, they are yours to have. It has quite a bit of wear on the feed roller lugs. Any parts that are subject to wear are likely just as bad as yours. All of the knobs and such are there, and I have two count them two covers for the pulley side. I'll hang on to it for a while. If anyone is interested you can contact me for pictures of individual parts. I live just outside of Orlando Florida if you want to come and get it.
  13. Well, thank you all for the input, I've decided to abandon this project. There would be machine shop expense involved, and even if I was able to overcome everything, I think I'm just putting lipstick on the pig here at this point. There is a guy a few hours from me that has a pretty nice Tecshsew Bell skiver, and might be interested in a sewing machine trade, and if not, I do have the Barnslely's.
  14. Yeah, he would come out every couple of months, take orders, and when the shoes came in you would buy them right out of the trunk of his car!
  15. Yeah, rich history there in St Louis. I'm from Kansas City myself, and then moved around the Midwest a few times when my dad transferred. I miss the Midwest. Good honest, genuine folks. Others in the forums have said that MSC isn't much interested in trying to help in any way with this old equipment, but I appreciate the tip just the same. Have you acquired any of that good ol Made in St. Louis U.S.A. shoe machinery? I don't think there is much U.S. shoe manufacturing anymore. Redwing still makes some of their shoes here, but a lot of it is imported now too. Redwing has their own tannery too I found out a while back. I don't remember the name, but I'm sure I have it written down somewhere. I'll look for it. I'm sure there are others. Even Mason shoes is still hanging on, but it's all imported. I remember when I was younger, there was this older gentleman who must have been 80 that would come out to the shop and take your Mason shoe order.
  16. I thought I would pass this along, because it lends credence to the Manufacturer's Supplies Company Bell Skivers as being possibly a German import for what it's worth. I decided I need to take the seals out of this gear-case. They are marked CFW, which turns out to be Carl Freudenberg Weinheim, a German company from 1849 that is still in business today. Interestingly enough, they started off as a tannery, and didn't get into the sealing business until the late 1920's and developed the revolutionary simmerring in 1932, and named it after the Freudenberg developer Walther Simmer. The Campbell Randall Parts list/ Service manual for this machine, refers to the seals as Simmerrings. Freudenberg company history, It's good read if you like that kind of thing
  17. Yes, absolutely on the vacuum table, that will be a nice compliment to a "someday" bell skiver. I appreciate your input, that at least settles the issue as to whether it can be put back or not. It hard a hard life in a Florsheim shoe factory. The guy who was maintaining their equipment in house was doing his best I think to keep the old girl online by packing grease into the gear case along with the oil to slow the leaks down. I got it from a rancher in Ocala along with 3 singer sewing machines from the same factory, so it's a nice story anyway. I think I would be better off to track him down and give him $20 to take it off my hands, but that's not a half bad idea with the separate motor! I literally just broke my Barnsley skiving knives out last night, but it is just a hobby, and I do indeed like tinkering.
  18. There it is, an empty gear box, and missing shaft from the gear box to the material feed assembly.
  19. I might be interested in a parts machine if anyone has one. I don't know how you would go about shipping something like that? This thing must weigh 100 pounds or more.
  20. You nailed it on the missing cover. I had noticed it missing, but didn't think much of it. There appears to be a missing gearset and transfer shaft arangement that drives the feed roller just as you said. I'll post up some pictures in a bit. This thing was basically free to me. It was thrown in with a sewing machine lot that I bought a few years ago. It is history though, and I hate to see it go to the scrap yard. Thanks Danne, I was able to learn from that thread that my missing knob (in the missing cover), is a sharpening stone dressing tool.
  21. You may have noticed that I have 2 right side covers sitting on the table there
