shoepatcher
Content Count
1,838 -
Posts posted by shoepatcher
You have to grind the sides of the spring down so they do not stick out past the outside diameter of the needle bar. I assume that is what you mean by a lot of sanding. Also file down the grove in the needle bar cut out if here is a thread grove worn in it.
glenn
Go to Kwok Hing in Hong Kong. Good feet prices. Hooks check Cerliani and Hirose. Great aftermarket hooks. Adler # is 068-00-181-4. Hirose # is HAD-68. That Hirose hook is on eBay right now for$99.99. Grab it at that price. I have used them for years. Made in Japan. Ceriiani hooks made in Italy. Aftermarket feet are cheap for the 67 Adler. Remember, this is the small bobbin model. The 167 is the big bobbin model. Aftermarket slide plates are out there as well.
glenn
nice job. You get the rust off the balance wheel.
Start with pics of set up and items you are sewing please.
glenn
Original gears were hard. Try Sitomaco.es in Madrid, Spain. Making aftermarket gears for the 29K1 and a few other parts.
glenn
H4 Pfaff 145,545 normally use the needle system #190 which is longer than the 134-35 system.
glenn
Pics will help us see it functioning.
glenn
How long is the belt and how many cogs are on it?
glenn
Pic of the machine? The brochure should tell you the max. height of the foot lift.
glenn
On 3/22/2024 at 9:21 AM, Uwe said:Can you elaborate on that please? That aluminum burr is new to me, I’ve not come across that type of belt in my online searches. A link to a source would be great.
will try to get a pic of it for you. Sorry for the lateness.
glenn
Consew make a copy of this. Not sure the model #. That me be a source for replacement.
glenn
I have an Adler 205-370 so these feet not of use to me. Sorry
glenn
Put the head in the front or between the seats. Take it off the table!
glenn
I prefer the hollow ploy belts with the aluminum burr. Even better than the solid belts.
glenn
441 feet compatible with most all 441 clones. The damn blanket foot that come on the genuine 441 is useless. Whoever designed that and it is very big and wide should be shot.! Piece of junk as far as I am concerned. Not usable on most projuects.
glenn
Buy a used 1341 then.
glenn
Hook you do not want to fool with. Anyway to lower the roller foot?
glenn
Can you lower the roller foot anymore so as to be tighter to the roller feed ring?
glenn
pull balance wheel and clean that. Looks great so far! remark all oil holes with red paint stick.
glenn
Also look at the Juki 2341. 3rd generation machines.
glenn
Sandt and Shoen were German made clickers. One bought the other but I do not know who bought who. I would research in Germany for the manuals.
glenn
feet out of sync with the feed dog. Feed dog supposed to be coming up when inner presser foot and needle come down. They all should meet at the top of the throat plate.
glenn
4 hours ago, Old Coach Saddlery said:I wonder if SO means special order.
That is what I am thinking. They made an HL high lift version and a HHL high high lift version with I think a 1 3/8" clearance of lift.
glenn
New tech HA441
in Leather Sewing Machines
Posted · Report reply
pic please.
glenn
