Patent Elastic was the early name for the Claes I believe. They started in 1869. There have been about 15 plus manufactured of the shoepatcher with the early design like you see in front of you. Singer came out with a shoepatcher in 1877 and their design was new and unique. Adler came out with the 30 class in 1900 which was a copy of the UFA/ 29 class. Adler had an earlier design like the old shoepatchers which was a 29 class. I have one. Bradbury had a few shoepatcher designs starting in 1872.
glenn
You need DA part #0667105100 which is the stud for synchronizer. Remove plastic plug and tap the stud in place. This is what the synchronizer mounts on.
glenn
You have lots of parts. Need a servo motor for it. Does the engraved line on the front of the base say 8345-6 or 8346-6? It has an early Claes cast iron stand almost like
the Pfaff Metro Spezial that was a Claes in everything but name. Claes sold machines to Pfaff that Pfaff out their name on it. What questions do you have on the machine?
glenn
Ok here is one thing that most people do not know about and Adler. The needle bar height is adjustable. You have to have the height set correctly even before you time the machine . If the height is wrong, machine will never sew correctly. Contact me and I can walk you thru the adjustment.
glenn
Your Adler is a 1950's , 1960's machine. It is a big bobbin high lift machine. It uses needle system 332LG and 332LL LG. first is round point, second is leather point. What people do not know is Adler shoepatcher can get out of time as far as the needle bar goes.. If you want to install a servo motor on it, I can walk you thru how to do it. Been working with shoe patchers of various makes and models for over 40 years. Let me know.
Singer came out with the 153 class which was copied by Seiko for the Seiko model and the Consew model 227. Singer made a narrow throat walking foot. Not sure of the exact class. Think it was a 123 or 126. I saw a picture of one years ago. I believe the Pfaff 335 came out before the 69 Adler.
Go to PfaffIndustrial. Find the Pfaff 1245 section. Download the instruction manual, parts list and mechanics manual which you can download and print off. That will give you most of the instructions you will need.
glenn
I wanted to let our readers know I recently came across some new old stock timing belts for a Singer 168 W or G post bed walking foot machines. All the belts are unused in good condition. I had to clean them up because they had been in bag for a few years and were dirty and dusty. Now clean and ready for Use. I have the cloth belt #264004 and the neoprene belt #264123. As far as I have been able to determine, these belts are no longer available. Contact me if you need one please.
glenn
