shoepatcher
Everything posted by shoepatcher
  1. If still sewing backwards, the feed eccentric has to be 180 degrees out of adjustment. safety clutch out? glenn
  2. Loosen the lock screw on the spring and see if you can tighten the regular screw on the spring to increase the tension. Spring is up and seems to be catching on the thread. glenn
  3. Derust, clean, oil and see what you got.. she is an old girl. Missing cover plates. Alasdair got any threading info? glenn
  4. clean the machine up first and oil it good to see how it turns,\. Glenn
  5. Push the lever down for reverse. glenn
  6. I have new levers C. glenn
  7. The 29K31 is a big bobbin long arm shoepatcher. Your part number is wrong. Singer did not make a 82202. They made a 82020 needle plate for the big bobbin. I have 82020 plates. Original Simanco plates unused or New old stock. Price is $55.00 plus shipping. I do not have that many. It is compatible with the 29K30 and 31 machines as well as later big bobbin Singers. Let me know if you want it. glenn
  8. Send me pics of your bobbin winder please Amy. Lets see if you are missing anything. glenn
  9. Gears and rack are worn. Too much play in those areas from your video of the shuttle carrier. With no wear, the shuttle carrier should hardly move when you turn it by hand. You look at the drive pinion, following pinion, short rack and long rack for wear. Also check the bushing that the shuttle carrier shaft goes thru. You might have to replace all of those as well as the bellcrank. I have rebuilt shoepatchers for over 45 years so I know what areas to look at. glenn
  10. You can sew #138 on a Pfaff 335 but you must enlarge the hole in the feed dog and inner foot to accommodate the #138 thread. I also just touch the the corners of the space bar on the the machine. That is where the gap on the bobbin case is that the thread passes by the each stitch. 335 Pfaff do not have a bobbin case opener since they are a horizontal hook machine. glenn
  11. P means 4 motion drop feed. H4 is high lift. Probably using needle system #190 Nice machine glenn
  12. I have a manual written by Singer for the complete 29K70 shoepatcher. Will try to find it. glenn
  13. ok Your thread controller disc is off. It is just below the tension. Loosen the black screw and make sure it is in the center of the slot. Unwind the tension nut and take the beehive spring out Stretch the spring out grabbing each end of the spring. That will increase the tension in the spring when you put it back on and tighten it. By hand, turn the balance wheel and let us watch the hook pick up the top thread from the needle and let it come out the feed dog. Video needed of this. This will tell us if the bobbin case opener is set correctly. We can then tell you what we noticed is wrong. glenn
  14. Stitch length lever set at zero? pics please of machine glenn
  15. Constabulary stated earlier it was screw #544383 which is supposed to be the same as #237. Specs 9/64" x 40tpi. I would have bet it was metric since Singer changed a lot of parts and screws on the 29U series which was made in Japan not Kilbowie where all of the 29 machines were made after 1923. glenn
  16. Pics of the needle bar and the throat plate alignment. glenn
  17. For Pfaff 335. First set stitch length to 0. Remove the little cover plate to the left of the reverse lever. There is a big straight slot screw behind it. Loosen screw and it will allow you to move the rock frame with needle bar inside it. You turn the balance wheel until towards you and bring needle just above the feed dog hole. Now center needle in feed dog hole. Tighten big screw so that it holds. Turn balance wheel and see if it is centered in feed dog hole. If good, tighten screw good and tight. If not, re loosen screw and re center the needle in the feed dog hole. Tighten everything up if centered. Replace cover plate and set stitch length to max. Turn wheel by hand to see if everything aligns. Now good to go. glenn
  18. A lot of 30-1 parts no longer made. I have a lot of early 30-1 parts but in Michigan and they are not cheap. I would try to find a machinist to try and make you the end of the drive rack so with all the teeth plus some length. It then can be welded or pinned. I know for a fact the long rack no longer made for early 30 class. I even tried to have Adler make them. They would not. You can find used rings in Germany. The bell crank can still be ordered I believe. The lobes on the end are worn and could be welded up and re profiled. Nothing will be cheap. Great machines glenn miller
  19. thread size and needle you are using? More pics of the the tension area please. Also the model plate in front. Pics lease. glenn
  20. No I always to to restore machines to as close to as original. The reason is the engineers who designed it know more than I do. Plus they sew better. glenn
  21. The inner foot is out of sync. There is a screw for adjustment in the front of the machine if i remember. When you loosen it, it allows you to re-center the inner foot and the feed dog. Will be in the the mechanics manual for a 145, 545,1245 .
  22. Possibly. Grey Consew made by Seiko. White ones made in China. as to whether there was some crossover, maybe. glenn
  23. They did not come with reverse. This one had been retrofitted. Bobbins, order for 733 R Consew. Needle systems are 7x1, 7x3, 794. This machine will sew from #138 to #415 nylon and polyester thread. Bobbins same size as 97-10 bobbins. glenn
  24. Pics of the machine please. Does your machine have a bobbin winder on it? glenn
