shoepatcher
Everything posted by shoepatcher
  1. Safety clutch out? glenn
  2. The U series of 29 machines were made in Japan in late 1970's early 1980's.
  3. Singer came out with the 153 class which was copied by Seiko for the Seiko model and the Consew model 227. Singer made a narrow throat walking foot. Not sure of the exact class. Think it was a 123 or 126. I saw a picture of one years ago. I believe the Pfaff 335 came out before the 69 Adler.
  4. PROBABLY NO LARGER THAT #138 ON TOP, #92 ON THE BOTTOM. >Y MAY NOT HANDLE #138 ON TOP SO GO TO #92 ON TOP. GLENN
  5. go to a #24 NEEDLE. hole made by #23 is not big enough for the thread to come up thru the hole. glenn
  6. Go to PfaffIndustrial. Find the Pfaff 1245 section. Download the instruction manual, parts list and mechanics manual which you can download and print off. That will give you most of the instructions you will need. glenn
  7. I wanted to let our readers know I recently came across some new old stock timing belts for a Singer 168 W or G post bed walking foot machines. All the belts are unused in good condition. I had to clean them up because they had been in bag for a few years and were dirty and dusty. Now clean and ready for Use. I have the cloth belt #264004 and the neoprene belt #264123. As far as I have been able to determine, these belts are no longer available. Contact me if you need one please. glenn
  8. ring is broke in your picture
  9. what part broke on the Adler? I have parts for Adlers. glenn
  10. thread size and needle you are using? glenn
  11. Y You get a copy of the service manual from Constabulary? glenn
  12. what color you looking for? glenn
  13. I have one for a 195 and a few for 1295, 1296 but none for 595. glenn
  14. yes original 206RB was a triple feed machine. Came out in early 1980's if I remember. Made by Seiko for Consew as was the 206RB-1. glenn
  15. nice. Needs some cleaning up and some accessories like thread stand. Download the manuals to start. glenn
  16. I might have a copy. In the meantime, download the 1295 manual. the balance wheel on the 595 you got is definitely for an H4. Big! glenn
  17. Might be able to but will be expensive. Parts list will show parts that can be switched. Both 10 and 20 use needle system 81. glenn
  18. then the feed eccentric is out 180 degrees. You have pic of the machine? glenn
  19. Have Constabulary send you copy of the manual. Bobbin winder looks complete. glenn
  20. Maybe Not hooked to a servo motor correct.? glenn
  21. Put the shuttle carrier shaft in the bushing and see if it wiggles. Is so bushing is worn and needs replacing. bushing are pressed in. My late father came up with a way to remove the bushing a with a nut, bolt and big washer. can remove old one and replace with new one with those 3 items. The shuttle carrier should just turn in the new bushing with out any wobble. To take the long drive rack out, there is a connecting screw in an access hole in the back. Screw #89. That release the long wrack. I normally have to pull the replaceable horn to replace the drive rack, The teeth on your drive rack look go. Chances are wear is in the drive pinion and the following pinion. I will also tell you the bell crank is probably worn as well. To replace that you have to take the end of the head off. 4 screws hold it on. You also have to drive the piston pin that connects to the needlebar out. It is a tapered pin that drives out from back to front. glenn
  22. Dremel the corners very light with a sanding disc. Dremel the corners very lightly with a sanding drum.; glenn
  23. yes the gap on the spring to the bobbin case. spring should fit tighter. glenn
