richco
Everything posted by richco
Hello All, I just bought simplex sole stitcher,I am having some trouble with it when I stitcher a leather after 3 stitcher it start fraying thread i have checked the threading it looks fine,I am also using 1mm wax thread please help me if someone have trouble shooting manual for this machine or idea to solve this problem. Thanks
Thanks for reply,the top part is solid and don't get expend while tight.
Hello All, I am restoring this Fortuna model10A leather skiver,I am having trouble with understanding how the bell knife sharpener stone is held on the shaft it looks to me it was glued on when I tried to remove it from the shaft it broke in half stone measures 70x7x17.5 could anyone please confirm me if it glued on or there's any other part to keep it there.Thanks
What a great person you are Glenn tonns of thanks for helping me out.
Please check your PM box I have sent you my email.Thanks
Could you please send me measurements of it I can make it,just the spring steel and the adjuster is mild steel I do have milling machine and lathe to do the job I only need the dimensions please. Thanks
Thanks for reply, I don't have this long spring and the adjuster thinking to make my own simple enough to make if I can get the dimensions of the long leaf spring and adjuster pleas help. Thanks
This machine looking great I am fixing my 29k2 which is missing parts I have ordered most of the parts except the leaf spring and adjuster one of great member on here offered me the help and parts but I want to fix this machine cheap l am looking to make this spring by myself if I can get the measurements as well as the breaket measurements here are some pictures of my efforts.
1895-Singer 29 Walking Foot not Lifting
richco replied to JohannaT's topic in Leather Sewing Machines
I just bought 29k2 sewing machine few parts are missing also missing the whole assembly showing in your pictures could you please tell me if I can buy this part it looks like a leaf spring and looks like easy to make one please guide me. Thanks -
You can also check there website Makermag.com
In Brazil there is a company who make parts for old pfaff and other machines ,try them hopefully they have it. marketing@makermaq.com.br there email,
I still have to make a slot on top of the mount so front plate sit behind the mount.
I made the front mount,will figure out the front cover trying to upload the pictures of mount I made.
Hello All, I have Pfaff 191post bed sewing machine i found this machine from a shoe making company they want to throw it in the metal bin this machine missing feed dog arm,feed dog,throat,pins,front and side cover,outside holding bracket for post ,after searching almost 2 years i found feed dog and arm,i made my own pins,made side cover,i am now ready to make front cover which have a screw with the jam nut what this screw actually do and how far is this screw from the top if i can get the some measurement of the front cover i can make this plate, I am also facing some issues when i installed the feed dog arm with the feed dog it sits almost 7mm far away from the needle please help me.Thanks
Hello All i wondering if there’s Chinese clone for Pfaff 191 post bed sewing machine.
Any china clone for Pfaff 191-194 maybe i can use parts from clone machine hopefully cheaper then oem parts.
Thanks a lot for the contacts i have sent them my list hopefully i will get these parts. I am in Calgary.
Hello All, I have a pfaff 191 post bed machine i am missing all the parts from the post,i did try most of online stores and local stores but no luck can any one please help me to find these parts here is the list of the parts i am looking.for 91-010165,91-010896,91-048300-93 or 91-048131-04,91-058258-04,91-000422-25,91-047858-04,91-010964-91,91-048377-04,91-000089-15,91-047143-04,91-048138-04,91-047061-04,91-048122-04,91-047054-04,91-012453-45,91010950-91 is there any china machine math to pfaff 191. Thanks
I did send them email waiting for there reply, hopefully they will send me something.
Hello All, I am looking for Techsew 810-2 post bed twin needle sewing machine overhaul (engineering service)manuals I got this machine used,left hand side bottom gear was replaced by me now I need instructions how to install left side post correctly and time it please any one can help me with the manuals, even golden wheel CS820 repair manuals will work for this machine. Thanks
Hello All, I had lots of other issue with this machine which i now able to fix with the help of members here, I am having trouble with auto reverse feed lever there is no spring tension on the lever when, Ii set the stitch length by the diel pin does not touch the cam which move the lever updown been reading manual and trying to set it but no luck can anyone please help me with this issue. Thanks
Hello Constabulary, Thanks for your reply, i did try with the reverse lever all the down,stitch look good then i try to run the machine when lever all the way up stitch was very nice and leather feed through,now i know some settings are off on reverse feed lever,if you have any better idea to fix it please let me know. Thanks
