First of ESSAYONS BROTHER!
Joe knows what t means folks
So sharpening this is something that I learned from my grand father people will argue but here are my two cents you can leave it on the table or put it in your pocket.
My grandfather could sharpen a blade so sharp looking at it would cut you. Lol not really but you get the idea.
Heres what he taught me
First off angle of the blade...... it doesn't have to be exact. A blade wil cut according to the way you cut with it. The angle i hold a blade may not be the same angle as you hold it so angle is all subjective to who is cutting with the blade.
Second take the edge off every blade when you first get it. This is done by running the edge toward the stone as if you are trying to slice a paper thin sliver off the stone.
The reason because of rule one you and i hold a blade slightly different because we are different people. HHe always said " You will know you are getting there because it will feel right" sounds crazy but it is true the blade feels different when you find YOUR angle gliding across the stone . It just literally feels right.
3rd once you have that bevel from taking the edge off go the opposite way with the blade to put your edge on it. Instead of taking the edge toward the stone now you take it away from the stone. This will sharpen it.
always start a new knife or blade with a medium stone then go to a finer stone like an arkansas stone.
after getting the edge so it will catch hair. now you strop it
three colors of rouge in this order on seperate strops
1green
2white
3red
Strop it just like you did when you sharpened it.
Use Light pressure not hard, like your trying to romance the blade " You sharpen a blade like you romance a girl boy light and easy. It's a love affair not a war. Treat it that way. " is what he used to say when i was learning to sharpen.
things he said to NEVER do.
Never use a wheel to sharpen a blade it creates heat and you can untemper the blade. you use the wheel to shape a blade not to sharpen it and when you shape it your constantly quenching it to hold that temper.
Never use sandpaper its not a block of wood its metal you want to polish it not scratch it.
that's me and Papwas 2 cents and what I learned from a man who could sharpen a blade so sharp it would cut you looking at it.
you know that scene in the movie body guard when he takes the silk sash from her neck throws it over the sword and it slices it as it falls. I did not believe that was possible. My grandfather showed me it was with his bowie knife. My grandmother was pissed beacuse he used her scarf to demonstrate. ( We got in alot of trouble together lol)
Hope it helps Sapper
