Melonie
Everything posted by Melonie
Pro Edge Skirt Chaser-Drill Burnisher is like new. I bought it just a few months back and used it very lightly but didn't end up needing it. I am selling it for $35 plus $5 for shipping. Has seven grooves, 1" flat, 1/", 3/8", 5/16", 1/4", 1/8", 1/16" rounded grooves with the steel shaft and made from cocobolo wood. Keep in mind that this burnisher is specifically made to be attached to a drill press and the drill press is not included.
Where could I find their contact information?
Thank you, sir! As always your response is extremely helpful. I ended up taking my machine to someone who knows a lot more about them than I do. I felt like I just kept setting more things off with each solution that I tried. He now says the machine is running backwards (although the motor is turning the hand wheel counter clockwise like normal). I can't think of what could cause that. It must be the needle bar then. The hook is hitting the bottom of the needle rather than the scarf
I have a cb227r and made some adjustments to the bobbin tension in order to perfect the stitches for the type of leather that I was using. It was working great, but I ended up getting my needle jammed at one point and haven't been able to get it back to normal since. I have a feeling that there are multiple things that are slightly out of alignment thats causing all of this trouble. One problem I am having right now is that when the hook on the bobbin case comes around, it hits the needle. Also when I try to sew, no thread is coming up. Is this a needle bar height issue? If so, how can I know where the needle bar needs to be?
Here are some photos more specs can be found here: http://www.solar-leather.com/cowboy-cb227/ Condition: Like new (purchased brand new 4 months ago, lightly used, consistently oiled) includes everything that it originally came with, plus some extra thread I am asking 1500 (plus shipping if local pickup is not an option) I updated my post to include the price, I am asking for 1500
I'm selling my CB227r that I purchased new in March 2017, along with 4 large spools of bonded nylon thread and two packs of needles. The machine is fantastic, I just didn't end up needing it as much as I thought I would. I would rather send it to someone now to be used and buy one later if I need it again rather than let it sit. The machine was purchased for 1700 and thread was $18/spool, shoot me your best offer. I live in South Carolina if you are interested in checking it out or picking it up
Help please: Timing ever so slightly off
Melonie replied to Melonie's topic in Leather Sewing Machines
Thanks, Sandy. How do you adjust the needle bar? -
I have a CB227r and the timing is just barely off so that my lower thread does not catch on the upper thread. It looks like it only needs to be rotated about 5-10 degrees to be fixed. I am wondering if there is an easier way to adjust the timing that doesn't require going too deep into the machine since the adjustment needs are so small.
Yes, the new thread I'm trying was bought at the same time, same suppliers and brand, but this one is a cream color and obviously a different size. My other one was brown.
Today I switched from my usual #138 thread to #92. I changed out the needle and triple checked my threading but for some reason the bottom thread keeps coming up. I've adjusted the top tension both ways but I can't seem to get it right. Any suggestions??
Thank you so much for the detailed advice, Dwight! I will definitely look into this process too
Thank you all!! I don't know why I never thought about using adhesives. Contact cement it is!
Hi everyone, I am reaching out in hopes of discovering the methods that you use to hold your leather in place as you sew. I have a CB227R and I LOVE it, but sometimes when I am sewing multiple layers, some of of the layers slip out of alignment and result in a crooked stitch and just a lot of complications altogether with the shape of the product. I am dealing with 5 oz oil/chrome tanned leather, but it is not very oily to the touch at all. I often use those little black office clips to hold parts in place as I sew, but I have a feeling that there are some much better methods that I don't know about.
Haha thanks!! I feel like a clumsy kindergartener all the time. I have a nice stash of useless leather that only gets bigger and bigger
I feel like when your products are made mostly by hand a promotional video showing your process can be very captivating to your audience. People will love to see the workmanship behind your products and will be that much more reluctant to purchase the cheaper, factory-made stuff. Do you agree?? Here is one that was just made for my leather journal business. (Contact info for makers of the video: 864-436-8680)
It does seem to get a little better when I increase the tension on the top thread. Should I try the bottom thread as well?
Thanks everyone for the advice. I started working away on the machine and am amazed. I am only experiencing one problem right now. When I do the reverse stitch, those last stitches don't seem to hold too well and they kind of unravel. How can I make sure that the last stitches are secure? Is this a thread tension issue?
Thanks! I just figured out how to thread it, started sewing and was blown away with how easily and smoothly it sewed through my leather. I had to do a little adjusting with thread tension, but so far so good!
I am reading this manual up and down! I can only find 2 short videos for this machine in YouTube. It's funny...I never thought to take such precautions when I was tearing up my parents stuff as a child
Is there an easier way to get the belt on and off? I had to lower the machine on the hinges just to get it on. Maybe I have to much tension on the belt? I'm hesitant to make adjustments because it seems like everything was set up perfectly on it for me.
Great catch! There was a hole there for it. Thanks
Thanks! Do you mean the belt that runs from the sewing machine to the motor?
This beautiful Cowboy 227r just arrived last night from Neel's Saddlery. I assembled it all last night and from what I can tell it is ready to go, but I'm really nervous to do ANYTHING after I turn it on. I've never worked with this kind of machine and I'm afraid I might be missing something before I try it out. So I'm just looking for any experienced advice before I start. maybe it's just to tell me to stop being afraid and get on with it thanks in advance!!
