Cbm
Everything posted by Cbm
  1. Thanks will this fixed it it works now
  2. thanks i dont know about that but definately learning quickly
  3. I really shouldnt have had to replace so many things when I am finished this machine will be virtually new the main feed bar was cracked the presser bar was cracked the thread release bracket etc etc I accurately put everything back together thanks to mr.grosse,s videos and the navy manual but unsure on eccentric.
  4. I replaced many parts including the arm shaft so this is a new eccentric and I dont know at what point to lock it down.I understand that the inside foot has to hit the feed dog along with the needle when adjusted properly but at what stitch length is the eccentric at full lift etc.yours looks great but I am new to this.
  5. Yes the presser bar lifting eccentric is out of adjustment
  6. I have a similar problem on my 111w155 the timing seems ok but the foot is barely lifting but it is lifting
  7. I believe that will only help if the eccentric is clocked properly to begin with constabulary
  8. Not really I have that info I replaced the arm shaft and bearing and I dont think I have that eccentric clocked properly Thank you though
  9. 111w155 presser bar
  10. i am having this same problem with my 111w155 i can lift the presser bar up with the lever but it doesnt actuate from the cams movement from the back of machine and all connections are tight. I am new to this forum and have seen this touched on in different ways but cant find the reason for this problem in past posts.I also know this is an older post
