Michiel
Content Count
175 -
Posts posted by Michiel
I have one
but its to big to post for me
sent me a dm
or may be a moderator can post it here
On 3/9/2024 at 2:53 AM, PEU said:the other is a wheel with felt on the sides
With this type of tensioner, the idea is to make two (or one and a half) turns.
The idea is that the wheel turns with it but experiences resistance from the spring being tightened.
The advantage over the other system is that it is less sensitive to variations in thread thickness.
The pre-tensioner is to keep the wire tight around the disc so that the disc turns with it.
Hello joanah,
This play is very common in old machines.
Usually it is due to play in different joints (which add up).
If you have the impression that there is one joint that has more play than the rest you might indeed consider addressing that one (but usually the play is in several places).
It is also a question of whether only the part you want to replace is worn, or also the shaft it rotates on. (Often one of the two parts is of a softer material, but how that is here I don't know).
I bought a lathe and milling machine to possibly fit new parts but haven't gotten around to it myself yet -
Did you find a parts manual?
https://www.college-sewing.co.uk/parts-books/durkopp-adler-parts-books.html
de presser foot is probably not in it but you will find it online
In my experience these are good machines
Myself i would consider to-change it to a one needle version ( but its less work to install an extra tension unit and a presser foot)
I think its a good buy.
even if you have to replace the belt.
i once bought one in the same condition (i think) replaced the belt, did all the adjustments by the book and have a great machine.
(but i think: do not fix it when it’s not broken)
kind regards Michiel
Nice work,
After i made my cams i figured out that by making them a little larger i could make my stitch with also wider.
i bought a wider feed dog needle plate and foot from global (which fitted my older bernina) and was able to enlarge my stitch with
From small to much wider
Thinking about it:
when you use thick leather a cilinder arm is great and there are not much advantages with a post bed.
But for thin stuff a post bed is more versatile in my opinion.
I think that’s why most members here are for cilinder arms (and they are right)
It depends on the material and the design of your projects
A postbed is great for top stitching bags
I have cilinder arm and post bed machines , but when making bag’s I always use my postbed and hardly a cilinderarm
On 9/17/2023 at 3:07 PM, sandmanred said:Maybe picking up a dead thread but I too just picked up a Chandler 217 with the cam box but only one cam. I'd really like to find the 3 and or 4 point zig-zag cams if anybody knows of a source?
I tried to 3- print them
worked but i was not 100 % satisfied
the Bernina favourite (household machine) shares the same hook and has the same cams inside
I bought one for the hook and finally pulled the cams out: they are the same as the old bernina 217 cams
the global has an other size cambox and cams i believe
Nice machine!
i looked last week for someone:
college sewing sells extra wide feed dogs, needle plate and foot for this machine (just in case you want an extra wide zig zag and you do not already have them)
With triple feed and needle feed machines very often the side “play” from the needlebar can be removed very easy
see the picture
the part my screwdriver is on should move a little bit to the needlebar assembly
the screws are on the backside
do not make it too tight ! (A litle bit of play is better for the machine)
You will need a smaller pulley on your motor to slow down your machine….(in the title you mentioned a large one)
When you remove the inner foot of a triple feed machine you wil have a needle feed machine.
You will need an other type of outer foot (or roller foot as is in this kit)
but to work good you need also an other set of feed dogs and needle plate
its not clear for me if the sent you only the roller foot or also the other parts
I usually use a small nail for that
which I cut to size -
I would look for a service manual and follow al the steps to set it up in the right order (so not try only to solve one problem but go trough the manual step by step)
by doing that you will and up with a well adjusted machine working like it was when it left the factory
https://www.duerkopp-adler.com/fileadmin/dag/Media/Downloads/269/S_269.pdf
20 hours ago, Beanwood said:I'm stil playing with my Brother LZ1-B651
Is this similar to the brother LZ-B652? (The early sailrite)
That is a very nice zig zag machine
With most zig zag machines the hook is too early at the left sticht and late at the right stitch
the hook of this machine goes a little bit faster when making the right stitch and slower on the left one (you can see the mechanisme at work on the underside of the machine)
its very helpful with this 12 mm stich
it doesnot have the walking foot
but i know this machine and the new original sailrite:
the vintage brother has much more quality
4 hours ago, CowboyBob said:What I've seen happen alot on these is the hole elongates (I guess from the needle pushing into the far side away from the screw),loosen the needle set screw & see how much play the hole has in it,I'm betting you need a new needlebar which we do have in stock.
I would start with this suggestion ….
and otherwise get the needle bar rocker frame out so you can see if the needle bar is bent
sometimes if you take something out you discover what caused the problem
or, if not, when you clean everything and put it back sometimes the problem is solved (or not)
If your needle or needle bar is not bent,
my gues is the frame your needle is in is not in the right position.
The frame can taken out so when it is loose or not 100 % in the right position or angle the needle does not meet de needle hole in the middle
I Think its called the needle bar rocker frame
regards, michiel
I think the pfaff 437 has a subclass with some kind of walking foot
(and it is a zig zag)
but its not a sailmaker or something like that…
Thank you!
this will do
Looking for parts for Adler 67
in Leather Sewing Machines
Posted · Report reply
College sewing is also a good source if you donot find them in your neighbourhood
https://www.college-sewing.co.uk/parts-by-machine/durkopp-adler-parts/durkopp-adler-67-sewing-machine-parts?p=2
