woolfe
Everything posted by woolfe
20 Dummy Guns To Sell
woolfe replied to woolfe's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Kahr P380 Sold -
4" XD sold -
Sig 229 with rail sold -
380 auto -
Beretta Storms both sold -
Dummy guns $35 each shipped. 30$ for each additional. Will consider offers for the lot. In no particular order: Ruger LCP with Crimson trace aluminum cast Smitth Bodyguard Rings H&K USP Compact Rings H&K 45C aluminum cast Walther PPS aluminum cast Taurus 738 TCP aluminum cast Sig P238 with sig laser aluminum cast Sig P230 no rails Rings Sig P226 rails RIngs Sig P229 rails Rings Sig P225 no rails RIngs Sig P226 no rails Rings Sig P229 no rails RIngs Sig P239 no rails RIngs Springfiled XD 4" Rings Springfield XDM 4.5" Rings Kahr P380 RIngs Smith and Wesson .38 SPL Rings
Dummy Guns For Sale
Yes. The ruger LCP with CT has it in front of the trigger guard. I still have the LCP with CT. The LC9 with CT is gone. -
Dummy Guns For Sale
Rubber pads are gone -Sig P290 gone -Smith model 4506-1 Gone -Ruger LC9 with Crimson trace Gone -
Got the following dummy guns left. Some are aluminum and some are blue guns, ask if it matters to you. Some of the safeties have been ground off. $35 each shipped, $60 for two shipped, $90 for 3 shipped, etc. I also have two 1" thick 12" x 12" gum rubber molding pads from McMastercarr to be used with a hydraulic press or equal http://www.mcmaster.com/#gum-rubber/=wxe78q $85 for the pair -Beretta PX4 Storm Full size -Beretta PX4 Storm sub compact -Keltec PF9 -Ruger LC9 with Crimson trace -Ruger LCP -Ruger LCP with Crimson trace -Smitth Bodyguard -Smith model 4506-1 -H&K USP Compact -H&K 45C -Walther PPS -Taurus 738 TCP -Sig P238 with sig laser -Sig P230 -Sig P226 rails -Sig P290 -Sig P229 rails -Sig P225 -Sig P226 -Sig P229 -Sig P239 -Springfiled XD 4" -Springfield XDM 4.5" -Kahr P380 -Smith and Wesson .38 SPL
Closing Small Shop
SOLD 1911 5" Operator w/ Rails and Springfiled XD sub compact 3" -
Closing Small Shop
Glock 17 SOLD This is what I have left: Two gum rubber pads for use with a hydraulic press 12"x12"x1" 40 durometer They were purchased from McMaster Carr. New they are $83 each! $90 shipped for the pair of them. The Toro 3000 Dummy guns: 1911 5" Operator w/ Rails 1911 5" 1911 4" Beretta PX4 Storm Full size Beretta PX4 Storm sub compact Beretta 92FS Keltec PF9 Ruger LC9 with Crimsontrace Ruger LCP Ruger LCP with Crimsontrace Smith M&P Shield Smitth Bodyguard Smith model 4506-1 H&K USP Compact H&K 45C Walther PPS Taurus 738 TCP Sig P238 with sig laser Sig P230 Sig P226 rails Sig P290 Sig P229 rails Sig P225 Sig P226 Sig P229 Sig P239 Springfiled XD sub compact 3" Springfiled XD 4" Springfield XDM 4.5" -
Closing Small Shop
Glock 19, 26, 36, 21 all SOLD -
Closing Small Shop
Pull the DOT snaps are all SOLD Springfield XDS 3.3 SOLD H&K P7M8 SOLD -
Closing Small Shop
T-nuts and machine screws SOLD -
Closing Small Shop
M&P Shield SOLD -
Closing Small Shop
3" 1911 SOLD -
Closing Small Shop
I replied to you Paul. Since I can no longer edit the original post I will post when Items are sold. Sig P238 SOLD I also have two gum rubber pads for use with a hydraulic press 12"x12"x1" 40 durometer They were purchased from McMaster Carr. New they are $83 each! $90 shipped for the pair of them. -
Closing Small Shop
Mags sold -
Hey all, I've been dragging my feet on doing this for almost 2 years now. The time has finally come. Artisan Toro 3000 $1600 I'm the original owner. It comes with everything it came with new. Flat top table (not installed in pic), 4 bobbins, 3 different presser feet, misc tools, oil, work light, DVD. I'm also throwing in the thread shown in the pic white, black, brown, and tan. The thread is a mix of #277 and #346 and 2 packs of needles. I cannot ship this. It's located in Raleigh NC. Pull the DOT snaps in bulk. I have roughly 500 each of the Caps, Sockets (hard strength), and Studs, 250 each of the posts asking $250 shipped, I don't want to separate these. A full box of 1000 regular strength sockets $175 shipped. These are all in government black. Will do $400 shipped for all of the snaps. I used 6/32 x 3/8 black machine screws and 6/32 T nuts to attach the studs. I have a few hundred of both I can throw in for another $20. Dummy guns $35 each shipped. $5 off per gun if you buy more than one. Some of the safeties have been ground off. I would make an indention in the leather to match the requested safety position. On the 1911's I drilled a hole and used an after market safety to mold them. I only have one of the after market safeties so you will most likely get one with it ground out and a drilled hole for the safety post. In no particular order: Kimber Solo 1911 5" Operator w/ Rails 1911 5" 1911 4" 1911 3" Beretta PX4 Storm Full size Beretta PX4 Storm sub compact Beretta 92FS Keltec PF9 Ruger LC9 with Crimsontrace Ruger LCP Ruger LCP with Crimsontrace Smith M&P Shield Smitth Bodyguard Smith model 4506-1 H&K USP Compact H&K 45C H&K P7M8 Walther PPS Taurus 738 TCP Sig P238 with sig laser Sig P238 Sig P938 Sig P230 Sig P226 rails Sig P290 Sig P229 rails Sig P225 Sig P226 Sig P229 Sig P239 Springfiled XD sub compact 3" Springfiled XD 4" Springfield XDS 3.3 Springfield XDM 4.5" Glock 19 Glock 36 Glock 26 Glock 21 Glock 17 Crimson Trace laser for Kahr 437 $100 shipped...No battery I have a Kahr 380 dummy with a Crimson trace 433 bolted to it floating around somewhere. $100 shipped for the laser when I can find it. $35 for the dummy... This is assuming I can find it. WIll use PayPay for everything.
A Couple Holsters I Made For Myself!
For the holster belt loop attachments I've been using something a little different. I use the standard 6-32 T-nut sandwiched between the two pieces of leather. But then I add a piece of 1mm thick rubber between the belt loop and holster body. I find this stops the belt loop from spinning and still allows enough movement to allow the belt loop angle to conform to the body. As in when you go from a seated to a standing position, I don't like the idea of having the belt loop in a fixed position. I find it more comfortable if it can move a little. I couldn't find a place that sold rubber washers like what I wanted so I make my own out of bicycle inner tubes, another hobby of mine so they don't cost me anything. I believe the material is Polybutylene. I use a 7/8" punch to cut em out and a hole punch in the center. They make a world of difference compared to nothing there. Here is a picture. -
The leather is just folded over on the mag carriers. -
Thank you! -
Seems like a holster maker would have many many holsters. Unfortunately its not so, for me at least. Seems like I always have to decide between making money or a new holster and money almost always wins. LOL The 1911 set I've had for a while now, the Sig mag carrier and holster I just made. The Sig grips are from Larry Davidson. http://www.davidsonknives.com/ I absolutely love the grips. They look great and most importantly feel great too.
I know this has nothing to do with holsters or leatherworking. I'm only sharing it here because I thought other holster makers might like the idea or even want to use the targets themselves. The idea was not totally mine it was a spin off of my GF's idea and I thought it sounded like fun. I made a bunch of printable targets and posted them on my website. 70 to be exact. Also found out I'm not the first to do this. There are lots of free printable targets out there. Figured it could be good advertisement. Anyways feel free to use the idea or targets yourselves. Enjoy! http://woolfegunleat...page=page&id=13
