ScottEnglish
Everything posted by ScottEnglish
Topy sheet soling
ScottEnglish replied to ScottEnglish's topic in Shoes, Boots, Sandals and Moccassins
Hello again. What is the hardest wearing sheet soling that you've used or heard of? I've been using 5mm thick Caster tyre tread soling which is rated at 85 on the Shore A scale of hardness. It wears far too quickly. Thanks. Scott -
Hello again. I want to obtain a contact adhesive for bonding soles to footwear that doesn't require heat nor a clamp to be effectual. The best contact adhesive I have found so far is Bochem Boterm GTA. But it requires heat and a clamp. Has anyone used contact adhesives manufactured by Anglo Adhesives or Caswell Adhesives? Do these need heat or a clamp to be effectual? Thanks. Scott
Hello. I wish to acquire sheet soling that is hard-wearing. I have heard that Topy in France makes such soling. My current soling is rated at 85 on the Shore A scale of hardness. It wears too quickly at the heel. Does anyone here have experience of Topy soling in regard to wear? Please share this with me. Thank you. Scott
Hello. Has anyone any experience with contact adhesives manufactured by Anglo Adhesives or Caswell Adhesives that are suitable for gluing soling to leather? I would like to know what is involved in each step of application. My current contact adhesive requires two coats of glue followed by heat to activate it before bonding surfaces under pressure. Ideally, I would like a glue that doesn't need heat to activate it. Thanks. Scott
Thanks everyone for your replies. Scott
Hello. I recently bought a chrome tanned leather side from a well known English tannery. The flesh side is dry and the grain side lacks the wax that is usually present. There was also a bird feather and tiny amount of bird poop on it! I think they may have sent me something past its best. What do folk think? Also, the neck looks to be present on the side. Is this useable? This is not the first time that I have received dry leather from a supplier. A few months ago I bought a shoulder of vegetable tanned leather that is very dry and stiff. Not the same supplier. Many thanks. Scott
Eyelets for lace holes
Thanks fredk. -
Does anyone know of a business in the United Kingdom that sells eyelets for lace holes? The only eyelets and tools for fitting them that I know of are those by Ivan and C. S. Osborne. Neither are suitable as the eyelets are too large. I am thinking of buying eyelets with a 4 mm hole if they are available. Thanks. Scott
Water resistant leather?
Thanks to you all for your observations, contributions, and thoughts. Scott -
Well, I have tried the contact adhesive and ground rubber mixture for soling moccasins. On several pairs. I walk a reasonable number of miles weekly on tarmac and concrete. I find the contact adhesive and ground rubber soling wears very quickly. Too quickly. One solution for extending the life of my mocs is to make the soling thicker by spreading more layers of the mixture on to the underneath of them. But it is time consuming and the fumes are unhealthy. The other solution, which is far more appealing, is to just use thicker leather for the soling. Probably buffalo. Or bison on your side of the pond. I would like to know whether the leather soles on the moccasins made by Arrow Moccasin Company are resistant to water. My experience is that leather soaks up water once the finish on the grain side is worn off. If the soles on the Arrow mocs are not resistant to water, then why do folk buy them? Scott
Contact adhesive
Thanks for the useful information fredk. -
Contact adhesive
Thanks chrisash. I will have a look at the EVO-STIK website. juck: I thought you might have forgotten the link! Thanks. Scott -
Contact adhesive
Thanks jcuk for your input. To clarify, are you referring to Woodweld when you say it is used in the shoe industry or an Abbey England product? Scott -
Contact adhesive
Thanks for the reply Grumpymann. Have you used Woodweld on footwear that has become sodden during use? Scott -
Hello. I bought a tin of Bison Kit contact adhesive which I have used when making moccasins. Unfortunately, when they get wet the adhesive fails and parts separate. Having just looked on the manufacturer's website, this limitation is noted. Can anyone recommend an alternative contact adhesive that does not have this limitation? Thanks. Scott
Thanks Matt S. Scott
Why are awls for making holes diamond shaped in section and not round? Ta. Scott
