Members Dink Posted February 8, 2008 Members Report Posted February 8, 2008 I cannot decide the correct place to post this so I will try here. Here is the question My bell knife splitter is on about a 4' long table with the splitter to one end and the motor toward the other. I need to replace the motor, and in interest of saving space I would like to shorten the table, and mount the motor directly under the skiver. In order to do this I would have to flip the motor around, and that in turn would revers the rotation direction. Will it work like this? would it hurt anything? Does this make any sense? Thanks for any feed back you may have. Dink Quote
Members rgerbitz Posted February 9, 2008 Members Report Posted February 9, 2008 I'm not much of an electrician, but I think most electric motors can be rewired fairly easly to run in either direction. Maybe yours can't, don't know. Good luck, Rob Quote http://gerbitzquarterhorses.com/
Moderator bruce johnson Posted February 9, 2008 Moderator Report Posted February 9, 2008 Dink, I thought I replied to this earlier, but appears that my dog ate the homework. My clutch motors have had a switch to reverse the direction of rotation. If you just swap ends and don't change the rotation, I would suspect the feedwheel would be going in reverse. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Dink Posted February 10, 2008 Author Members Report Posted February 10, 2008 Thanks bruce johnson said: Dink, I thought I replied to this earlier, but appears that my dog ate the homework. My clutch motors have had a switch to reverse the direction of rotation. If you just swap ends and don't change the rotation, I would suspect the feedwheel would be going in reverse. Quote
