7 hours ago, chiefjason said:
Let the leather dry thoroughly.  Usually a few hours.
Pull off extra thread, the ends get most of the transfer
Keep the needles close to the ends, the thread at the needle gets a lot of dye.
If your thread is soft look for a hard bonded nylon thread,  The bonded coating does not pick up as much.
+1.  I normally measure the distance I am stitching, multiply that by 4, then add a bit for thread length.  I use .8mm thread and saddle stitch.  Most of the dye transfer is on the ends which are cut off when done.
In God's Grace,
Pastor Bob
"While we were yet sinners, Christ died for us." - Romans 5:8
www.PastorBobLeather.com
YouTube Channel
:17:  :16:
btw, on the odd occasion when I reckoned a thread was too grubby, I pulled the thread out and re-stitched with new clean thread
Thread is cheap. You'll spend / waste more time trying to clean a length of thread worth less than 0.1c than its worth. Pull it out and re-stitch and be done with it. Also trying various solutions on the thread to try to clean it may damage the leather or its finish, and that bit is ultimately worth more
17 hours ago, Mungo said:
Sometimes after I’ve sewn my leather work the threads pick up the dye and appear dirty. Is there a way to clean them to make them nice and white again?
I assume you follow the usual practices to minimize dye ruboff.  Fiebings Pro Dye and Fenice Colorfast dye produce less ruboff than other dyes I've tried.  Prior to sewing, buff the work with a soft cloth until there's no more dye rubbing off.  I quit using Tan Kote as a finish after sewing because it works like a dye solvent and discolors even bonded nylon thread.  Then there's the failsafe - use dark colored thread.
