Try the search box up in the top right corner, and use the term "head knife" in quotations to see a list of threads discussing them.
Stohlman's book on leathercraft tools explains how to use and sharpen these tools.  One aspect of the choice is using a disposable blade versus spending time and money on sharpening equipment.
  • CFM
4 hours ago, Nathanjespers said:
Still getting used to this site. Can anyone direct me to a thread on pros and cons. head knives, draw knives, scalpels, utility razors and such and such?
Thanks a bunch folks
Right tool for the job, the knife depends on the type, thickness, shape of the leather or pattern you intend to be cutting. so you will be getting a lot of confusing reply's unless you can give more info. Are you making saddles or watch straps?
As you've noticed, there are all sorts of knives available for leatherwork, at all sorts of prices. Search YouTube for 'knives for leatherwork' ; 'beginners tools for leatherwork' and similar headings, and you'll see what's available, and their pros & cons. Also watch videos on the things you'd like to make and you'll see what other people use.
Here are a few comments, in no particular order  --
Round knife - it has a semi circular blade with two points and will do most things; the disadvantage is that it takes practice & experience to use well, and they are expensive
Head knife - similar to a round knife but it has only one point, which makes it cheaper and easier to use. Have a look  at videos by JH Leather, she uses a head knife for most of her work
Stanley/utility/box cutter - simple, cheap, and easy to use; you can re sharpen the blades, and even new blades work better if they've been sharpened on a fine stone & a strop. You can do good work with a box cutter, have a look at videos by Ian Atkinson/Leodis Leather, he uses one for most items
Clicker knife - with a chubby handle and interchangeable hooked or straight blades; reasonably priced and easy to use & sharpen
Rotary cutter - such as Olfa or Fiskars; good for straight cuts on thinner leather like wallets or some bags
Japanese Leather Knife - with its distinctive asymmetric blade, but once you get used to it, it's good for straight cuts, gentle curves, & skiving; reasonably priced and easy to sharpen
Basic leather knife - a simple style with a wooden handle and a thin blade about 4" long; cheap, easy to use & sharpen
Small craft knife or scalpel - such as Exacto or Swann Morton; replaceable blades; OK for thin leather & fine work such as wallets or watch straps, but too light for anything thicker
Skiving knives - There are two main types - one is like a hand held chisel, and the other is usually just a plain strip of steel with an angled blade at one end. As you watch videos you'll see them both in use.
These are, I think, the most common types, but no doubt you'll see other styles & variations as you gain experience
My suggestion - start with a box cutter, you probably have one already, then once you've got used to leatherwork, decide what's next
Whatever you choose, you will need to be able to sharpen, usually with a fine stone or abrasive paper, and a strop - but that's another story
Just one thing, a draw knife is a two handled knife used in woodwork, not leather.
Here's a suggestion - have you got a strop yet? You'll need one for sharpening your knives, whatever type you get
Make your own from oddments of wood & leather, it's easy enough and will get you used to cutting and using leather. Search YouTube for 'how to make a strop', there are loads of videos
Green chromium oxide stropping compound is as good as any; it's cheap and a small bar will last for ages
