Members Kjamesro Posted April 27, 2022 Members Report Posted April 27, 2022 I have a Singer 66-18 with the Simanco BA motor. I know it is not a heavy leather machine but want to use it for lightweight garment leather. The motor runs at high speed BUT has no power. Without the belt, I can easily stop the motor with my fingers. On the machine, the motor can barely run, even without thread or material under the presser foot. I can hand turn the balance wheel easily and I have cleaned and oiled the machine. The motor works better when the belt is tensioned too loose. I have replaced the drive belt. I don’t feel like the problem is the machine but don’t know what to try next. Thanks in advance! Ken Quote
Moderator Wizcrafts Posted April 27, 2022 Moderator Report Posted April 27, 2022 3 hours ago, Kjamesro said: Simanco BA motor That is a toy motor for household/domestic sewing machines. I looked up the 66-18 and it is a domestic sewing machine. It is meant to sew thin cloth. You can probably upgrade the feeble motor with a 1.5 amp model sold on eBay. Get a new controller with it. Don't expect professional results from a domestic sewing machine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Kjamesro Posted April 29, 2022 Author Members Report Posted April 29, 2022 Thanks Wizcrafts. I can turn the balance wheel by hand and it sews 2 3-4 oz veg tan no problem. the motor spins at high speed by itself, when I attrach to the machine it can hardly turn it, without anything being sewn. The motor should but does not run the machine. I can spin the balance wheel without the motor attached and it cycles many times, so the motor is bad , I just don’t know what to service i on it….replacing the motor is a good idea. thanks Quote
Moderator Wizcrafts Posted April 29, 2022 Moderator Report Posted April 29, 2022 Here's the motor you need, with a control pedal. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted April 30, 2022 Report Posted April 30, 2022 On 4/27/2022 at 3:23 PM, Kjamesro said: Without the belt, I can easily stop the motor with my fingers. You could try and take apart the motor and check and see if all the connections are good, the brush is good, the windings are good. But honestly it is probably not worth the effort as you can get a new 100 watt domestic sewing machine motor off Amazon for about $25. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
