Members ZigZag Posted May 24, 2022 Members Report Posted May 24, 2022 Hi all, I’m trying to retime my zig zag Adler 98, but despite loads of research I can’t find a service manual. The 98 is based (I think on the 67). Does anyone have any reference that might help. thanks Nick Quote
Members Michiel Posted May 24, 2022 Members Report Posted May 24, 2022 Hi Nick, i do have the same machine (and never found a service manual But timing this machine is like other sewing machines: you do not need to know an needle bar height you can do it by turning the wheel to raise the needle bar ca 2 mm from the most lower position than adjust the hook so that the hook meets the needle than adjust the needle bar height so that the hook point is in the middle of the scarf (the space above the needle hole) because it is an zig zag machine you need to pay a little extra attention because the hook is early on the left side of the zig zag and late on the right side You can time it with the zig zag off and the needle in the middle and after wards check with zig zag on the widest setting to see if it is timed well for both sides but what i sometimes do is time it on the left position in a way that the scarf is just above the needle hole hope this helps kind regards michiel Quote
Members ZigZag Posted May 24, 2022 Author Members Report Posted May 24, 2022 Thanks Michiel, much appreciated. I’m aware of the left / right timing issues, but it keeps missing a left hand stitch every once in while and when timing, the hook does look a little low in the scarfe. I’ll try dropping it a mill and see how it goes. thanks Nick Quote
