Edsbear Report post Posted May 28, 2022 Hi, I have an industrial Brother LS2-B837 which sews good but only if the top tension is very high. The bobbin tension very smooth and not tight at all and even if I slacken the bottom tension more it makes no difference. If the top tension is slackened to a reasonable amount, the thread knot shows on the underside. Hook timing is good. Other machines I have used don't need to be anywhere near as tight to make a good stitch. I wondered if anyone has come across this before and found a solution please? Many thanks Quote Share this post Link to post Share on other sites
