Mike516 Posted July 26, 2022 Report Posted July 26, 2022 Anyone with an AK-20, what oil do you use? Im out of the stuff it came with and wanted to get some more. I was going to use sewing machine oil, but wasn’t sure if it was the same. TIA Quote
Members BtownMN Posted October 22, 2022 Members Report Posted October 22, 2022 On 7/26/2022 at 10:57 AM, Mike516 said: Anyone with an AK-20, what oil do you use? Im out of the stuff it came with and wanted to get some more. I was going to use sewing machine oil, but wasn’t sure if it was the same. TIA I know this is an old post but there wasn’t a response. The oil in an AK20 strap cutter is 85W-90 Gear Oil, not sewing machine oil. It’s a closed system so you should not have to add oil unless you are changing the oil. As long as you can see a little oil in the window then you don’t need to add oil. Quote
