Members wintertree Posted January 12, 2023 Members Report Posted January 12, 2023 Hello Everyone...I have yet to get this new to us Adler patcher to to stitch..It simply will not pick up the bobbin thread...I have read many posts and spent considerable time trying to solve this..finding very limited info on trouble shooting this machine...We are retired saddle makers and have enjoyed 30 + years with various stitchers .....Can anyone direct me to a SERVICE manual for the Adler 30 series patchers ?...Surely past machine techs had access to such literature... Thankyou for any help...Regards...Wes Quote
Members Constabulary Posted January 12, 2023 Members Report Posted January 12, 2023 Are you sure you are using the right needle? The 30-7 is using a longer needle than most other Adler 30 or Singer 29K patchers. The needle system for the Adler 30-7 / 30-70 is 332L. The L in this case means LONG. I have a Adler 30 mechanics manual but file is too big to upload here so send me a PM with your email address Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members wintertree Posted January 12, 2023 Author Members Report Posted January 12, 2023 Sorry forgot to double check the email address.(for some reason I often forget the numbers) (age...hmm) dandwes66@gmail.com Quote
Members shoepatcher Posted January 12, 2023 Members Report Posted January 12, 2023 Your needle bar may not be set at the correct height. You can change the needle bar height on Adler's. They have an eccentric to move the bar up and down. It is in the service manual. Look for the service manual for a 30-70. Same info applies to the 30-7. glenn Quote
Members wintertree Posted January 13, 2023 Author Members Report Posted January 13, 2023 Still looking for a SERVICE manual for Adler Patcher (30-70)...if anyone can help...just need some proper specs to get things sorted on our new to us machine..grey square-ish adler...one of the newer ones I suspect.....very limited wear and tear noted when I looked thru the unit..everything seems tight...but was sitting idle for years...(probably needed a tune up).. would like to include it into our repair business...there are times when the long arm and swivel sewing head would be useful.. Thanks for any leads or links to a Manual...Wes Quote
Members Constabulary Posted January 13, 2023 Members Report Posted January 13, 2023 22 minutes ago, wintertree said: Still looking for a SERVICE manual for Adler Patcher (30-70)...if anyone can help...just need some proper specs to get things sorted on our new to us machine..grey square-ish adler...one of the newer ones I suspect.....very limited wear and tear noted when I looked thru the unit..everything seems tight...but was sitting idle for years...(probably needed a tune up).. would like to include it into our repair business...there are times when the long arm and swivel sewing head would be useful.. Thanks for any leads or links to a Manual...Wes check your emails - it´s on the way. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members wintertree Posted January 13, 2023 Author Members Report Posted January 13, 2023 Thankyou Constabulary.....Pleased to say we got the patcher to start stitching this morning....still some tuning up to do....checking some of the other parts of the machine that need adjustment...I used two different colours of thread...(up and down) as sometimes it can be confusing when the upper thread gets tangled under your work pce...misses the odd stitch....but we are in the ball park... Kinda spoiled when you are used to using an original Japanese Juki 441...both of ours worked flawlessly...never needing adjustment even changing from different weights of leather or fabric... Thankyou again for the help....Wes Quote
Members AmyP Posted March 4 Members Report Posted March 4 On 1/13/2023 at 3:24 AM, Constabulary said: check your emails - it´s on the way. Good morning I also am looking for a service manual for my Adler 30-70 shoe stitcher. I can not seem to get the bobbin wound correc. It seems that I may be missing one or more parts? Can someone please help?? Quote
Members shoepatcher Posted March 5 Members Report Posted March 5 Send me pics of your bobbin winder please Amy. Lets see if you are missing anything. glenn Quote
Members AmyP Posted March 12 Members Report Posted March 12 On 1/13/2023 at 3:24 AM, Constabulary said: check your emails - it´s on the way. On 3/5/2025 at 5:05 PM, shoepatcher said: Send me pics of your bobbin winder please Amy. Lets see if you are missing anything. glenn Glenn, here is a picture of my bobbin winder. I think it is stored on the back so it doesn't get in the way. I did find where it goes, directly under the hand crank. I don't think I'm missing anything. But idk for sure.-Amy Quote
