21 hours ago, Xaff2442 said:
What is the benefit of this design of speed reducer as opposed to just reducing the size of the pulley on the drive motor?
If you are able to achieve the slow speed control and punching power you need at that speed, you don't need a reducer. However, if your motor power drops too far down to punch the needle and thread trough the work at that slow speed, a reducer will allow the motor to spin faster while the machine turns at the desired slower speed.
For instance, I have multiple sewing machines that have analog servo motors like this one. This type of motor has a simple knob on a pot or rotary switch that varies the top speed. At the lowest top speed settings the torque drops down to the point the motor won't turn the machine over without help. I have to increase the speed setting a little to get the machine to turn over. This also translates to a higher slowest speed. If I really need to sew slower, and steadily, at a rate below what the direct motor give me, I can add a speed reducer. Some are 2:1, others are 3:1.
This hasn't addressed to part of the O.P's question about the difference between having a smaller motor pulley versus a speed reducer. I would try changing to a smaller motor pulley first. Adding a reducer is a hassle no matter what type it is. Plus, it requires an additional belt.
Note, that changing the size of the existing motor pulley may also require purchasing a different length v-belt.
Posted IMHO, by Wiz
