Lamar90
Hiding old tooling
I have some bits of heavy veg tan from an estate sale that has several pieces with some Sheridan-looking tooling. I’m not sure they’re carved, but they appear to be incomplete, so I don’t think it has been sealed.
I think I want to use them for letter shaped appliqué and so I wonder if I can disguise the tooling with a texture of some kind. I’ve never tried this sort of thing before, tho; so are there any best practices I can follow?
you can use the other side of the leather, its called rough out.
Do you have any pics ?  that would help too  :)
This is just a wild crazy suggestion, and  not seeing the pics, you could try finishing it off?? :dunno:
" Use the force"  ..just sayin'    :)
HS
...so, using the pieces as roughout isn’t my favorite idea but I can see it. I didn’t realize what I’m considering is so off-the-wall, but in more detail:
What I have is not quite a dozen “D” shapes, around 4x5” in size, with floral work on it. I may have ignorantly referred to this as a “Sheridan” style, but beside the point
I’ve recently done a project I’d like to repeat with Greek letters scaled to a 3” circle cut out of the leather and applied to a diamond stitched background. I don’t have much experience tooling leather, but:
i hope I can re-case the leather, and use a background tool to obscure the existing tooling and replace that with texture. I assume, if this works, that I’d work the leather before cutting it out, but there could be more considerations: will the leather relax and lighten the previous tooling thru multiple wettings? Would saturating the leather have a positive effect toward that end? I don’t expect the old marks to go away, I just want obscure them enough to make it useful beyond cutting into washers for knife handles or padding corners of shop carts. It’s 1/4” thick and I don’t plan to throw it away.
 you may pull it off if it hasn't been cut to deep, if its just a tracing or crafttool image I don't see why you cant. Some pics would help!!
 This is totally tooled on the inside with practice work, it was in my junk bin and i needed a sheath.
