  • CFM
modified my arbor press
removed the geared press arm
using a 1/4  rod coupling
forcefully with great care, drive the coupling into the tool recover hole in the. The presser arm
5963649B-B7F3-441A-B05B-8448DA06E16B.thumb.jpeg.9fb913d0d02914cfbdc683210ec44406.jpegDB2C2E4B-C143-4791-894D-8872DAE4F658.thumb.jpeg.d12989534323601c4a6a8bd843332993.jpeg5373291F-B000-43A1-A8B7-8D87D52109AD.thumb.jpeg.9abb00f05a7d623560416b770d73121e.jpegD66CF5D9-6E96-4EEE-A5C2-FBEA8D6DC02D.thumb.jpeg.b29b756bd7968e7fe195f9fae913c79e.jpegED3162C6-9490-4377-B332-0F4612F66F24.jpeg.0454b88ee9a2f1916e0d28702e07698c.jpeg
grind the rod coupling  so it fits OnTo the aluminum stamp
using a drill bit, remove the threads inside the rod kkcoupling.
Cut a 1/4” rod 1.5” long  , grind one end to a dull point
nowlets use the machine
1)…. Flip/invert the anvil that comes with the press. Use this tool to press large acrylic stamps,  I have pressed stamps up to 6” diamieter
2).   Press for stamps
3)..   remove the selector wheel from a broken hand punch, remove one of its cutter dyes
Ram will press down on the cutter dye to punch holes
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
My favorite method for many things ...
- Voltaire
- Aristotle
  • CFM
I stole that line fro an engineer in Texas
the plan called for a floor sink to be installed at a location that had a 4’x2’section of duct work in the way
I issued an RFI. And waited for an answer engineers answer was to forcefully with great care manipulate the top of the duct work to accommodate the p-trap (IE. Beat it)
This work was taking place in a university kitchen that was in operation.  I came down my ladder stole a stainless steel mixing bowl  cut round hole in the duck and set the bowl in it with the p-trap nestled in the bowl like a baby bird
The salad chef looked for his mixing bowl for an hour before  he gave up
side note,  shout out to a plasma cutter called Drag-un awesome awesome tool
D.C.F.M
