Hi/Moin,
I recently got into leathercrafting and now I want to make a cover for a ringbook. Making reusanle covers for Journals with flexible front and back are no problem. But the ringbook I will be making this for, has a hard back and front and the cover has to be reusable.
I am pondering ideas about how to make it so that the book can be inserted and taken out.
So far I only came up ideas which include press fastners.
Any ideas?
Best regards,
Lars
If you mean ring binders ie. https://www.amazon.com/Amazon-Basics-Economy-Binder-Showcase/dp/B077X9NMRC/ref=sr_1_11_ffob_sspa?crid=1CDJX5DQQVL08&keywords=ring%2Bbinder&qid=1691404293&sprefix=ring%2Bbinder%2Caps%2C108&sr=8-11-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&th=1
Don't the ring binders front and back generally open almost 180 degrees? so that the front piece and the back piece could touch behind the spine? Well anyway, the two I just looked at here will, thus putting on a cover would be quite easy.
Edited by Wepster
G'Day, I have almost completed a  recipe book cover, front and back for a client using 'hinged Split rings' , (google that) .They come in different sizes , I am using 32 mm .  Basically I have made   lined  hand stitched  leather covers  sightly bigger than A4  and to accommodate the holes on    A4 the pages ( provided)  , but no spine.  The client can add or remove as many pages as they want.
The pic is of a  rough diagram that I provided for the client . \
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
Here is how i did it.
