Members Moti Posted September 1, 2023 Members Report Posted September 1, 2023 Hello, I have a Global 9971 post bed sewing machine, the cheapest model, and it does not have reverse sewing, is it possible to add it?thought it was possible because there are models that have the option so it must be something that can be added or changed Quote
Uwe Posted September 2, 2023 Report Posted September 2, 2023 Your best bet might be asking the folks at Global (https://globalsew.com). They’re based in the Netherlands. Global’s Model descriptions indicate that only the LP9971 R-LH has reverse. LP 9971 – Single needle postbed machine with top driven roller, wheel and needle feed with standard hook. LP 9971 C – Same as LP 9971, but with Chinese hook. LP 9971 R-LH – Same as LP 9971, but with manual back tack and large hook. LP 9974 – Double needle postbed machine with wheel feed and top driven roller presser ( no needle feed) and equipped with standard hooks. Standard needle gauge 2,4 mm. LP 9974 C – Same as LP 9974, but with Chinese hook. Their manual for the 9971 machines shows an old Singer 111W style feed motion eccentric. I doubt that you can upgrade this to add reverse. https://globalsew.com/wp-content/uploads/2017/03/LP-9971-TD-Manual.pdf Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Moti Posted September 2, 2023 Author Members Report Posted September 2, 2023 Thanks, yes I talked to them they say it's not possible Quote
