Members Burkhardt Posted December 19, 2023 Members Report Posted December 19, 2023 7 hours ago, shoepatcher said: The length of stitch should NOT effect the tension. If the needle hole is too small, that will affect the stitch tension because knot will get hung up on the bottom of the piece you are sewing. glenn How could it not? The longer distance between each stitch will affect the top bottom pull because of the distance. A long stitch will be looser than a short one or are we not talking about the same thing? I'm looking at it as you do a long stitch on a curved seam and flip it inside out it's going to look loose where the shorter stitch will be tighter because of the distance. Quote
Members shoepatcher Posted December 20, 2023 Members Report Posted December 20, 2023 Never in my 45 plus years of sewing have I had the length of the stitch affect the tension. Sorry. glenn Quote
Members Cwagz396 Posted October 31, 2025 Members Report Posted October 31, 2025 Were you ever able to figure out the cause/solution of the tension issues? After taking it to the shop? Having the exact issue with my new-to-me PFAFF 1245 right now. It was running amazing and then I thread jammed it, threw the safety clutch (didn’t even know what it was at the time), retimed it according to the adjustment manual to best of my knowledge and the bobbin thread is looking exactly like yours. I tried tightening the top thread tension to see if that was the issue and it didn’t work. Tried loosening bobbin tension, nope. Ugh. Quote
Contributing Member friquant Posted November 2, 2025 Contributing Member Report Posted November 2, 2025 On 10/31/2025 at 3:50 PM, Cwagz396 said: Were you ever able to figure out the cause/solution of the tension issues? After taking it to the shop? Having the exact issue with my new-to-me PFAFF 1245 right now. It was running amazing and then I thread jammed it, threw the safety clutch (didn’t even know what it was at the time), retimed it according to the adjustment manual to best of my knowledge and the bobbin thread is looking exactly like yours. I tried tightening the top thread tension to see if that was the issue and it didn’t work. Tried loosening bobbin tension, nope. Ugh. @Cwagz396 Start your own topic, post close-up photos of the hook. Also post photos of the entire top thread path from spool to needle eye. We will help you figure it out Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
