Members AtomicLeathers Posted January 24, 2024 Members Report Posted January 24, 2024 Hello all! I am trying to make a EDC belt type tool pouch. I need to put in it a leatherman, a med size flashlight, a pen. I have made a belt case for a leatherman but it turned out not so good. I was wondering if anyone had made one before or has a template/pattern better then what I messed with? something along the lines of this? Thank you Thank you !! Quote
Members Mablung Posted January 24, 2024 Members Report Posted January 24, 2024 What happened with your first belt pouch? That might give you an idea for how to adjust your next pattern and make one for the belt rig you showed. That one doesn’t appear to be wet-molded, or at least not to a significant degree, so it would be reasonably simple to figure out the dimensions, based on the diameter/width and thickness of your tools and the thickness of the leather plus stitch lines plus belt loops. Might take a few tries and a few hacked-up pieces of craft foam, but you could make a pattern for that. Quote
