Members bcurrier Posted November 30, 2007 Members Report Posted November 30, 2007 ... Btw, the belt loop at the back is a single belt loop. You can do a triangular shaped loop which can be used with a sporran strap or go on a belt.russ I've never made one, but have worn them for the last 30 years or so as a piper playing in a variety of bands. I own one sporran, all the rest have been band kit. Not one has had a belt loop. All have had a pair of D-rings for the strap to clip onto. Quote
Members whinewine Posted November 30, 2007 Members Report Posted November 30, 2007 I've never made one, but have worn them for the last 30 years or so as a piper playing in a variety of bands. I own one sporran, all the rest have been band kit. Not one has had a belt loop. All have had a pair of D-rings for the strap to clip onto. Sporrans have a leather attachment on the back for a small strap with 2 dee rings (which will attach to the strap or chains). It is normally a triangle-shaped or double-bladed-axe shape. However, if one wishes to wear on a belt, one can expand the triangle loop so it can be worn on a belt. It was a simplification/modification on my part: most people don't wear sporrans & aren't familiar with that particular type of wearing arrangement. I should have been more specific to list that as a modification of traditional design. Sorry, my bad. Quote
Roger Posted November 30, 2007 Author Report Posted November 30, 2007 any pics of of the back? what size dee rings should they be? should they be mounted vertical or horizontal? Quote
Members whinewine Posted December 3, 2007 Members Report Posted December 3, 2007 any pics of of the back? what size dee rings should they be? should they be mounted vertical or horizontal? Beez: sorry to take so long to get back to you... I don't have shots of the back, but I'll try to describe as best as I can, what it looks like. Consider the 'double-bladed-axe' shape I mentioned earlier. It is approximately 3" long X 2-1/4" (at the widest part) X 1-1/4" (at the narrowest part of the axe shape). It is attached in a vertical manner (with 1 'blade' facing up & 1 facing down) to the back of the sporran, either by sewing the top & bottom or by using rivets. This will result in the narrowest part being on a horizontal plane. Into that narrow section is inserted a strip of leather with a solid dee ring at each end attached with rapid rivets (or it can be sewn, also). A decent size is a 5/8" strip & 5/8" solid dees. The leather strip just extends slightly past the narrowest part. The sporran chains & straps fasten to the dees. I hope this helps. russ Quote
Members Rahere Posted August 20, 2020 Members Report Posted August 20, 2020 It's actually just a mediaeval pouch, which mated with ideas from military cartouche bags to become white in the days of Victorian Rob-Royism. Hairy grey goat, or black leather, or whatever. Quote
