I can't seem to change my avatar, I have tried everything I can think of. The roseskull just changes, looks out of kilter and even after I delete it and replace it with the pic I want it just comes back. I want to change it to the same pic as my personal one. Dazed and cornfused in utah.
I deleted your avatar. Try it now. If it doesn't work, PM me the new avatar and I'll fix it for you.
Johanna
That seems to have done the trick, thanks....Jordan who the heck is that handsome devil in the rayban Daddy-O's
Edited by Jordan
alot of times when you change your avatar...your cache won't update and in the CP (control panel) you'll still see your old avatar (with a skewed image like you described) however your avatar has actually changed....you can usually get it to display correctly in the CP if you hold shift and press F5 (forced refresh)....or get someone else to check for you.....you can also delete your temporary internet files then come back to the page....or find a topic that you've posted in and check your avatar there....it'll usually show the new avatar
