Members MonteS325 Posted March 28, 2024 Members Report Posted March 28, 2024 New member here. I am looking to find someone who can make a copy of a historical leather and tin piece for me. I have access to the original, but the owner will not let me ship it to anyone, so I would have to supply any measurements needed. I have attached pictures. I am wanting a leather case that protects a wagon odometer. This is a container made of tin, just under 5" across, a little over 2 1/2" deep, with an opening at the top, that has two sets of rails inside that the actual odometer slides down into. Then the leather part of the case goes around the tin, protecting it, keeping the dirt out, as well as allowing for the case to be tied to a wagon wheel via two sewn on loops, opposite of each other. The opening of the leather case has an inner set of flaps, (these have broken off on my piece) that makes me wonder if the case has two layers of leather that circle the tin. the opening is secured with a strap and buckle. The thick lines of the grid squares on the paper in my pics are 1". I realize finding someone who can do both the tin work and leather work might be a challenge, but I have to start asking somewhere.
Members Mulesaw Posted April 24, 2024 Members Report Posted April 24, 2024 @MonteS325 Fascinating piece of measuring equipment. I am a bit tempted to give it a go, but I have a lot of jobs at the moment, so I wouldn't be able to do it straight away. Plus I am located kind of far from Texas (Denmark), so there'd be some shipping involved etc. My best suggestion would be to contact the local vocational technical college and ask if they have a sheet metal class. They should be able to solder the metal part for you. Then it would be down to finding someone near by who could sew the leather on it. Good luck brgds Jonas
Members London Posted August 2, 2024 Members Report Posted August 2, 2024 I Live in Texas, I could replicate the leather part of the case. I have no experience in tin, however if full historic replication is not required I can 3d print an exact replacement of the tin instead and cover that with leather.
