Members UpstateSCBill Posted April 19, 2024 Members Report Posted April 19, 2024 I have read a few different approaches to casing leather for tooling. My question is what is the best way to do it for a project that may take several sessions that might be separated by several days between each session? Will it maintain the proper moisture level by just keeping it in a plastic bag? It seems like if you had to rewet it that the already completed tooling would lose definition. By the same token would keeping it in a plastic bag with relatively high moisture also cause loss of definition. I am just about to begin learning and practicing on small pieces, maybe coaster size. But a project I will be working toward I will not likely be able to finish in one or even two sessions. And I will probably have multiple days between sessions. I am slow...especially if I want to do the best I can. Quote
Members UpstateSCBill Posted April 19, 2024 Author Members Report Posted April 19, 2024 Sorry but I believe I posted in the wrong subforum. If the mods could move it that would be nice. I don't want to double post. Quote
CFM chuck123wapati Posted April 19, 2024 CFM Report Posted April 19, 2024 On 4/19/2024 at 12:24 PM, UpstateSCBill said: I have read a few different approaches to casing leather for tooling. My question is what is the best way to do it for a project that may take several sessions that might be separated by several days between each session? Will it maintain the proper moisture level by just keeping it in a plastic bag? It seems like if you had to rewet it that the already completed tooling would lose definition. By the same token would keeping it in a plastic bag with relatively high moisture also cause loss of definition. I am just about to begin learning and practicing on small pieces, maybe coaster size. But a project I will be working toward I will not likely be able to finish in one or even two sessions. And I will probably have multiple days between sessions. I am slow...especially if I want to do the best I can. Expand A plastic baggie is fine, don't overly wet it just get it as close to the stamping dampness as you can before putting in the baggie. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
