Members RVM45 Posted April 24, 2024 Members Report Posted April 24, 2024 Friends, I want to make a lead-shot filled leather sap—and I would like it to be slightly fatter toward the distal end… Picture the shape of a speed bag or a light bulb—only not quite so pronounced. Also, I intend to sew all the seams and then turn the result inside-out to hide much of the stitching, and I intend to use four pieces… What kind of pattern do I use to get a slightly spherical ball on one end? If I make the ball end too pronounced, it won’t fit through the neck when I turn the leather inside-out. Is there any good rule of thumb, so that I don’t end up with a bag that won’t turn inside-out? What weight leather would y’all advise? Thanks! Quote .....Though I am forced to live in Exile in the Twenty-First Century; I am proud to retain my Citizenship in the Twentieth Century. .....RVM45
CFM chuck123wapati Posted April 24, 2024 CFM Report Posted April 24, 2024 First off have you tried the search function? I have seen quite a few saps on the forum. If I were to make one I would use heavier leather, hand sew or lace and not turn it inside out. I've never made a sap but most I have seen are flatter so you can put them in a pocket or hide them easier. Some even have spring steel sewn inside to give it some snap. You may even consider lacing instead of sewing. I haven't seen a pattern for a four piece sap you will probably have to think that one up yourself. This is a ball bag for lead balls I made 6/7 oz. leather to show you how much you could wet mold a simple two piece sap. I used bbs and just mashed them in with a dowel rod to get the leather wet formed. it is a three inch circle and formed to about 1 1//2" thick at the center, plenty for a sap. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members RVM45 Posted April 26, 2024 Author Members Report Posted April 26, 2024 Friend, Well duh... I do most of my reading over on the Holster sub-forum and it had never occurred to me that here might be articles/ tutorials on saps. Acrually, I Have little use for a sap as a utilitarian object. I was trying to recreate an olde tyme aesthetic from pictures of old saps that one sees... Some of the olde tyme saps look like—well, they look like they need a big dose of Viagra Thanks. ] Quote .....Though I am forced to live in Exile in the Twenty-First Century; I am proud to retain my Citizenship in the Twentieth Century. .....RVM45
