Members sign216 Posted May 6, 2024 Members Report Posted May 6, 2024 I found this vintage folding ruler, that I carry with me daily to confirm measurements. The gilded stamping about the automatic coal stokers adds real character, but I don't want it to wear away. Is there a wax, shellac, or other finish that will protect it from wear? Quote
CFM chuck123wapati Posted May 6, 2024 CFM Report Posted May 6, 2024 That is cool ! you might try resolene it is a leather sealer. It may harden or change the color of the case a bit so definitely try it or any product you go with on a something else similar before committing. Quote
Members sign216 Posted May 7, 2024 Author Members Report Posted May 7, 2024 Chuck, I looked up Resolene, and it sounds like a good application. Thanks, I'll give it a try. Joe Quote
toxo Posted May 7, 2024 Report Posted May 7, 2024 13 minutes ago, sign216 said: Chuck, I looked up Resolene, and it sounds like a good application. Thanks, I'll give it a try. Joe Remember to dilute it 50/50 with water. You can apply 2/3 coats letting it dry in between. It will put a shine on it. Quote
Members sign216 Posted May 7, 2024 Author Members Report Posted May 7, 2024 Toxo, Thanks for that tip. I'll probably do 3 coats, just to maximize the protection. Joe Quote
