I am particularly interested if the needleplate and feed dogs from 869 are interchangeable with 269
If anyone has knowledge on that I will be thankful
It looks like some feed dogs have not changed since the 67/69 model, but the needle plates are new for the 869 model.
In general, if two parts have the same part number in different parts lists (e.g. in the 69 parts list AND the 869 parts list) then the parts themselves are identical and interchangeable. When you look at the parts list, many part numbers will show on which model the part was first introduced (and hasn’t changed since.) A part number starting with 0067 was fist used on the 67, a part number starting with 0367 was first used on the 367, etc. Part numbers starting with 9 are not model specific.
The Durkopp Adler 869 parts list (https://www.duerkopp-adler.com/fileadmin/dag/Media/Downloads/869/TL_869.pdf) shows available sewing gauge combinations at the end. Some feed dog parts numbers start with 0067 (or 0467), the throat plate numbers all start with 0867.  That means the fed dogs will likely fit all models 69 through 869, but the throat plates will likely only fit the 869.
Here’s a screen shot of one of the pages from the manual:
