wilsonintexas Report post Posted May 24, 2024 I have a consew that i put a servo motor on and run at a max of 500 rpm fow slow speed work. i am not getting oil up to the top end to oil the mechanism. is there an adjustment ir differnt pump that works better at low speed? the pump now is a vein pump, i do not think i am spinning fast enough to create pressure. is there a gear driven pump? Quote Share this post Link to post Share on other sites
kgg Report post Posted May 25, 2024 7 hours ago, wilsonintexas said: I have a consew I don't know if the pump can be replaced but before you sew put a few drops of oil on the necessary parts then remove the thread from the needle and run the machine for a couple of minutes at high speed to drive the oil pump. kgg Quote Share this post Link to post Share on other sites
