elnedro
Magic Trick construction
Not even sure if this is the right section for this. But I didn't find a subform for Magic.
So I am trying to make a Chop Cup, and am hoping someone here has made one.
Without giving away the trick, was wondering what you material you used in making it that turned it from a regular cup into a chop cup.   if you are familiar with the gimmick you know what I mean.
I have the design figured out (it's basically a dice cup) but I can't figure out the last piece of this puzzle.
You simply take the one side of the last piece of the puzzle . . . sand it with some 80 grit sand paper . . . and Weldwood contact cement it where it belongs.
OR . . . put a concho on top of the cup . . . threaded into the last piece of the puzzle . . . hidden in it's lodging place.
May God bless,
Dwight
May God bless,
Dwight
brilliant. thank you so much!
