11 hours ago, TonyGreen3455 said:
hello
I stopped immediately after reading this )
sometime we have to think out of the box - many thanks for helping in that
great post, many thanks again.
start thinking about "singer 111" project - any sugestion what to avoid on this way?
PS
many thanks to all for your help and advices
looks like better choice for this project - Juki 563 instead of old Singer 111. prices for bouth in the UK very near (sometime).
small industrial walking foot machine which will be converted to tabletop for binding - any advise for the machine choice?
Juki 563 is excellent and 562 as well, the 563 has a larger bobbin. Both share accessories and certain pats with the Singer 111. Seiko STW-8B is another good machine and Singer 111 based as well.
On 10/17/2024 at 6:35 PM, Constabulary said:
Stop bouncing around with these stupid domestic sewing machines. Just don´t force them to sew things that they are not designed for. Having no space at home may be a reason but not a good one. ;)
Better invest some time and "brain grease" for setting up a proper industrial sewing machine for "table top use". Get one based on a Singer 111w / 111G -  or even better a cylinder arm machine based on singer 153. You can set it up for plain sewing (up to 9mm or even 12mm depending on the subclass) and even for proper binding work. You can get all the accessories you need for these machine for piping work, binding work, different feet, needle plates, feed dogs - just everything.
Having that said - setting up certain machines to run leather tape for binding is not a easy task at all (even for industrial sewing machines) - it works but do not expect that you "just" buy this and that and some odds and ends on Ebay or AliExpress and then you are set up for this task. You may run some trials and figure some errors. Guess how I know.
You have to start with a proper sewing machine and a proper machine for leather work can never be a stupid domestic machine. Basically you need the right machine for your sewing task. Yes some folks force them to do certain things but they remain domestic machines. Sewing a piece of leather and producing proper leathers goods are 2 way different things! Sooner or later you will run into a sewing situation that a domestic sewing machine never can handle. Guess why so many leather workers have more than just one machine? And some even have one just set up for binding edges.
Yes, it costs money and maybe more than you want to spend but life / your leather hobby will be easier with a properly set up sewing machine.
read more about binding edges - you may be surprised what you read:
https://www.google.com/search?q=binding+site%3Aleatherworker.net%2Fforum&rlz=1C1PRFI_enDE858DE874&oq=binding+site%3Aleatherworker.net%2Fforum&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTEwNDkzajBqOagCALACAQ&sourceid=chrome&ie=UTF-8
BTW - LW member UWE once set up a portable cylinder arm machine - just to give you an idea that you can set up industrial machine in a space saving way even with a powerful servo motor.
Thats what I meant with brain grease. ;)
Talking about space saving - I once made a "table box" from some old drawers for my Singer 212G141 because I´m barely using it and it is a bit longer that the 111G1566 and this way I can drop the box into the cutout in the machine table and I just change the drive belt and done. Not ideal but the most space saving way for me to run my double needle machine.
So think of singer 111 in a box like this ( see below) and a servo motor mounted in a way as UWE made it for his Adler machine... Its doable and you have a powerful versatile space saving machine then.
BTW - your project "Singer 212G" is over?
is there any chance to see the result - motor and controller setup, etc.
for some reason I'll not be surprised to see it under the machine base )
did you make any cover/handles for it?
As I said before the machine sits in the box and I drop the box in the table cutout of my singer 111G156 which has an under table servo motor and I just put on a longer drive belt. The 212G141 it self has no motor installed. No hard cover no handles. When it is not in use I put a soft cover on it.
Edited by Constabulary
