Members Antonispaul Posted November 4, 2024 Members Report Posted November 4, 2024 Hello to everyone..I have a bernina 217 6mm ,i has cam box with small cams..I bought it recently in good condition,but while the zig stitch works very good,when i enable cam box the sewing machine does a narrow stitch as long as the width is..In generally the cam box dont read the cams..I would some help if someone knows how i fix it.... Quote
Members Constabulary Posted November 17, 2024 Members Report Posted November 17, 2024 (edited) @Antonispaul the cam box has 2 levers, when looking from the front and from above the left one is to enable / disable the cam reader and the right one if for the "reader finger" that is following outlines of the cam. Maybe the set screw of the reader finger lever is lose? I only can guess. Edited November 17, 2024 by Constabulary Quote
Members Antonispaul Posted November 28, 2024 Author Members Report Posted November 28, 2024 Constabulary thanks you very much ,i went to a specialist man and he fixed the sewing machine Quote
Members Moti Posted November 28, 2024 Members Report Posted November 28, 2024 14 hours ago, Antonispaul said: Constabulary thanks you very much ,i went to a specialist man and he fixed the sewing machine What was the problem? I have the same issue Quote
Members Antonispaul Posted November 29, 2024 Author Members Report Posted November 29, 2024 The cam box didn’t work…The engineer set up the sewing machine Quote
