8 minutes ago, maddog12 said:
i have a consew model 28 there is no reverse on the machine i put on a servo motor that has reverse on it  would i be able to reverse the motor to back stich?
Short answer is no but you can turn your work to do it with the needle down or needle up and manually manoeuvre the work 2/3 stitches back and go over again.
