Contributing Member fredk Posted December 16, 2024 Contributing Member Report Posted December 16, 2024 Leather hardens incrementally as temperature increases above ambient or room temperature Quote Al speling misteaks aer all mi own werk..
Members ThisIsMyFirstRodeo Posted December 16, 2024 Author Members Report Posted December 16, 2024 4 minutes ago, chuck123wapati said: I recommend just air drying, or using a fan to speed up the process especially in AZ. But if you're set on trying it, then do your sperimentin with some scrap and let us know how it worked. Just a reminder that leather is still skin, so it can be cooked and if that happens its not BBQ its just ruined lol. Right now, I only have high 60s outside. As far as my initial thoughts, I would maybe start at 140F. From a hypothetical standpoint, I think I could mitigate any grease/oils by wrapping in parchment paper, but I don’t know if any smells/odors would impregnate the leather. Perhaps dusting with baking soda would prevent this… Quote
CFM chuck123wapati Posted December 16, 2024 CFM Report Posted December 16, 2024 I know many who dry their projects in their cars, it adds some heat and also tans/ darkens the leather. And a late comment on your first question. use a thinner welt, if you are making a taco-type sheath, one piece folded over and sewn then skive the inside of the bend along the spine so it will fold nicely. a two pice sheath just needs thinner welt. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted December 16, 2024 CFM Report Posted December 16, 2024 1 minute ago, ThisIsMyFirstRodeo said: Right now, I only have high 60s outside. As far as my initial thoughts, I would maybe start at 140F. From a hypothetical standpoint, I think I could mitigate any grease/oils by wrapping in parchment paper, but I don’t know if any smells/odors would impregnate the leather. Perhaps dusting with baking soda would prevent this… You are way overthinking this drying/ hardness problem IMO to cook a steak to medium rare you pull it off the grill at 120 degrees internal temp so that at 140 your leather will be cooked. I've made a lot of hard sheathes and holsters you don't need heat, they will be plenty hard if you limit the oils you put back in. Plus if you over-dry your leather in an artificial source like an air fryer it will just suck in the natural humidity of the atmosphere as it cools back down. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member fredk Posted December 16, 2024 Contributing Member Report Posted December 16, 2024 140* will cook the leather and probably shrink it to uselessness. 80* to 100* is more than enuf. At 140* you are getting into the specialist realms of 'cuir bouilli' Quote Al speling misteaks aer all mi own werk..
Members ThisIsMyFirstRodeo Posted December 16, 2024 Author Members Report Posted December 16, 2024 Thank you both for the input Quote
Members ThisIsMyFirstRodeo Posted December 19, 2024 Author Members Report Posted December 19, 2024 (edited) Didn’t want to risk any odors impregnating the leather, so I just left it to air dry on the counter overnight. Molded the sheath as tightly as I could to give it some structure, but not necessarily happy with the results. Perhaps it is the best I could reasonably hope for with the weight. Think I might just have to fabricate another layer for better rigidity. I know better than to change direction on the fly, but it is what it is… Suppose I should mention that this is a different project than the 12oz sheath I was originally talking about. THAT project I haven’t touched since I cut the stitches… Edited December 19, 2024 by ThisIsMyFirstRodeo Project confusion Quote
