Members craftsman827 Posted December 13, 2007 Members Report Posted December 13, 2007 Does anyone know the difference between the red & white Jewelers Rouge, for stropping swivel knives. Is one better than the other ? Would like to know anyones preference. All welcome Quote
Members CitizenKate Posted December 13, 2007 Members Report Posted December 13, 2007 I recently switched to the red rouge, and I like it much better. The red rouge is recommended for jewelers; it produces more of a high shine on the metal than the white rouge does. I can get my knife tips very sharp with considerably less effort than I used with the white stuff. Kate Quote
Contributing Member rdb Posted December 13, 2007 Contributing Member Report Posted December 13, 2007 The white stuff seems softer, and it takes more to lay down on a piece of leather. The red stuff seems harder, and goes down better. It seems to strop better too My opinion, if you can find red, use that. Of course, I was wrong once ...lol Quote Web page Facebook
Members whinewine Posted December 13, 2007 Members Report Posted December 13, 2007 (edited) Red is predominately iron oxide (rust). White is (I believe) predominately aluminum oxide. There are others, green (Chromium oxide, I believe, if I'm not mistaken, & I certainly could be, at this point), yellow & others, all with different chemical compositions , some of which are better for polishing certain materials and not others. While all these 'rouges' share the same name, only red rouge is truly 'rouge' (from the french, 'rouge'= red). Edited December 13, 2007 by whinewine Quote
HorsehairBraider Posted December 13, 2007 Report Posted December 13, 2007 As it happens I am a jeweler and work with both. This is what I can tell you, but remember - I actually use this stuff on jewelry, on a polishing wheel (hooked to an arbor, hooked to a motor and spinning at high speed) and do not do the sort of work you do. Rouge is red, and is used for polishing because it is very fine, and gives a high luster to gold and silver. This is partly because of it's color; it contains ferric oxide. Tiny amounts remain on the work but because of the red color are usually not offensive and actually give an attractive reddish glow. "White rouge" (it's not really rouge, rouge is a French word meaning red, so the white is simply a polishing compound) is a polishing compound that is more aggresive than rouge. By aggresive, I mean it will take off more metal than I would like while polishing, and do it more quickly. In extreme cases it can take off the detail in my work! However if you really need to cut down metal, a more aggresive compound than rouge is called for. I occasionally have a call to polish other metals, such as brass, bronze or steel, and therefore keep different polishing compounds around that are more aggresive than I would normally use on gold or silver. Neither compound is "better". It just depends on the job you need to get done. If you need an aggresive compound, white is more aggresive. If you are doing a final polish to a mirror shine, rouge is probably a better choice. (But it might take a great deal of work, polishing a very hard metal like steel!) There are actually many different polishing compounds. I am currently using a black compound that is water soluble, because the background on my sterling pieces is black, and the black does not show up as much if there are tiny amounts left. I use it on a chamois wheel and achieve excellent results. Quote They say princes learn no art truly, but the art of horsemanship. The reason is, the brave beast is no flatterer. He will throw a prince as soon as his groom. - Ben Jonson http://www.beautiful-horses.com
gtwister09 Posted December 13, 2007 Report Posted December 13, 2007 The names Buffing compound and polishing compound are generally used interchangeably and refer to fine abrasive fillers combined with greases which are formed into solid bars or liquid. Polishing Compounds are similar to sandpaper in that they are used from coarse to fine. A work piece that is severely scratched may need to be sanded down with sandpaper before polishing. Once the scratch depth is minimal on the work piece it is advised to start with the coarsest compound that is applicable to the material being polished. From there one should than move down to the next compound and so on until the desired finish is achieved. NOTE: It may not always be necessary to start with the coarsest and go all the way to the finest. This will depend on the condition of the material being polished. Jewelers rouge or red rouge is the finest compound originally developed by the jewelry trade for buffing precious metals. Blue all-purpose polishing compound is one of the most versatile compounds available and can be used on plastic and all metals. I have also attached a PDF of materials and compunds (from coarse to fine) that you might find useful. Regards, Ben Materials___Compunds.pdf Materials___Compunds.pdf Quote
Billy P Posted December 13, 2007 Report Posted December 13, 2007 I use both the Red and white rouge sticks. I bought both from Tandy years ago. Tandy used to only sell the red rough sticks, but then they started with the white for some reason. I've found that the red is more abrasive than the white. I keep to stropping sticks close by and will sometimes hit the blades with the red and then a few strokes with the white. That gives me a really sharp edge on my blades. Another thing is for my rough strops I usually make them using Crocus cloth. That is something that is almost like a smooth sand paper. When I did construction work, most of the time I worked in Maintenance Support for the contractors. The Crocus Cloth was used to help get a really good polished finish on some of the Valve Seats, and misc. Turbine parts. Anyway I've found it to be good stuff and I hope that I can find some more sometime soon as I'm down to just 3 or 4 sheets now. Some of the other compounds named are good to. Some people swear by something else that is called Yellow something. I haven't used it, but the ones I've heard from that use it I trust that are right as they are really good leatherworkers/saddle makers. Anyway I hope this helps a little, Kindest Regards Billy P Quote Billy P SideLine Leather Co. Leatherworker.net/Forum
Members craftsman827 Posted December 13, 2007 Author Members Report Posted December 13, 2007 This turned into a great tutorial. Plenty of good info on rouge etc. WHAT is good for stropping CERAMIC Swivle knife Blade ?? Quote
Members Skipknives Posted December 13, 2007 Members Report Posted December 13, 2007 I can't answer about ceramic blades,,,but as a knife maker I love a compound called "ZAM" it is a green blend (not greasy like other greens),,after I a make the cutting edge I switch to a 700 grit belt to dress the edge,,this leaves a fine "wire" on the very edge. then i load a soft buffing wheel with ZAM and strop the edge. (Not trying to blow my own horn) after this is done the cutting edge i achieve is better then a new razor blade. the soft buff has as much to do with the final edge as the compound does. ZAM also polishes the "Clouds" out of stainless steel better then any other compound i have ever used,,including pink-no scratch, white diamonds, and Red PS; when polishing blades on a belt sander,,the 1,200 grits and 2,000 grits use to burn the steel quickly,,,now with ZAM in the belt i can push harder and hold the blade longer to the belts before cooling them. Harbor fraight sells a small buff already on an arbor that can be chucked in a drill for stropping. just my 2 cents Quote Skip Slocum Phoenix Arizona http://skpslocum.googlepages.com/home
Contributing Member rdb Posted December 13, 2007 Contributing Member Report Posted December 13, 2007 Good tip skipknives... Here it is. The ad says it won't hurt jeweled stones. This might work on the ceramics? http://www.woodcraft.com/family.aspx?FamilyID=4244 Quote Web page Facebook
