Members MB1 Posted December 4, 2024 Members Report Posted December 4, 2024 (edited) Hi leather friends, Any idea on how to make this knot? It doesn't seem to be a bleed knot right? Help me out Edited December 4, 2024 by MB1 Quote
Members TomG Posted December 5, 2024 Members Report Posted December 5, 2024 Well, I can tell you that it is NOT a bleed knot. I used to know the name of it, but old age has erased that knowledge. I've made a couple of items using it years ago, and I use a short version to secure the ends of my dog leashes. Try this. Take 2 straps of leather, around 5/6 or so as it's easier to play with, about 3/4" wide Maybe 1". remember that you're experimenting and can adjust things after you figure out the technique.. Cut 2, 1" slits in each one, about 1/2" apart. Lay 1 on top of the other, with the slits on top of each other. I THINK I put the rough sides together, but not 100% sure. From the back side, pull both straps through the first slit, pull tight. Take the same ends and pull them through slit 2 from the back. Repeat for the length of the strap. I slapped together a quick demo photo. Sloppy, but you can get the idea. This is 1oz leather. Couple of points. Thicker leather tends to look better and hold together better. Make the slits twice the width of the leather strap. I use 1-1/2 for 3/4" wide 10/12 straps. Also, the leather thickness can affect the slit length. You will need to experiment with the spacing between the slits Good luck Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members GatoGordo Posted December 5, 2024 Members Report Posted December 5, 2024 Here is a link that shows using the braid in a dog leash. You will need to do it multiple times to simulate the continuous look. https://leathersmithdesigns.com/blogs/braided-leather-dog-leash-diy-/ Quote
