Members Lugubrious Posted December 5, 2024 Members Report Posted December 5, 2024 It was seeing fine earlier during my project but as of now it isn’t walking properly and cutting into the leather, if I sew on a smaller test piece of leather It sews fine. I am sewing through 4 layers of chrome leather, singer 153k103 Quote
Moderator Wizcrafts Posted December 5, 2024 Moderator Report Posted December 5, 2024 Something is jamming the feed motion. It may be that the top or bottom thread is binding. It could be on top, or in the bobbin and shuttle. Remove the cover plate over the shuttle and inspect the entire area to see if there are threads wrapped around it. Pull on the bobbin thread and see if it is binding. Look to see if any thread is trapped around the spring latch that holds the bobbin in place. I've had this happen when I did some jerky starts and stops. I also have found the top thread jammed on the back side of the tension disks, instead of being inside them. Then I've had top thread twist around a thread guide and bring the proceedings to a halt. If none of the above applies, verify that the stitch length hasn't changed to almost nil. If it has shortened unexpectedly, a part inside the head may have slipped. See if the stitch length spindle affects the length as you turn it. Turning it in shortens the stitches, and vice versa. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Lugubrious Posted December 5, 2024 Author Members Report Posted December 5, 2024 1 hour ago, Wizcrafts said: Something is jamming the feed motion. It may be that the top or bottom thread is binding. It could be on top, or in the bobbin and shuttle. Remove the cover plate over the shuttle and inspect the entire area to see if there are threads wrapped around it. Pull on the bobbin thread and see if it is binding. Look to see if any thread is trapped around the spring latch that holds the bobbin in place. I've had this happen when I did some jerky starts and stops. I also have found the top thread jammed on the back side of the tension disks, instead of being inside them. Then I've had top thread twist around a thread guide and bring the proceedings to a halt. If none of the above applies, verify that the stitch length hasn't changed to almost nil. If it has shortened unexpectedly, a part inside the head may have slipped. See if the stitch length spindle affects the length as you turn it. Turning it in shortens the stitches, and vice versa. I believe this might be the issue. This spring isn’t moving as I turn the wheel, i also notice a knock sometimes up behind at the knuckle. I’ve tried raising the feet and pressing the button behind the machine but that didn’t do anything. Quote
Moderator Wizcrafts Posted December 5, 2024 Moderator Report Posted December 5, 2024 Oil inside the head. Cover all of the crank shafts and rods that move. This might loosen it up. Lower the feet and see if it moves freely with the feet down all the way. It could be that something slipped and when you tried sewing your usual thickness, the cranks bound up. There should be an adjustment on the rear of the machine where a shaft sticks out and connects to the cranks that move the feet. This shaft would be adjustable up and down by loosening a large screw on the joining knuckle on the back. You can set the alternating height to only what you need, and which avoids a lock up. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Lugubrious Posted December 5, 2024 Author Members Report Posted December 5, 2024 3 hours ago, Wizcrafts said: Oil inside the head. Cover all of the crank shafts and rods that move. This might loosen it up. Lower the feet and see if it moves freely with the feet down all the way. It could be that something slipped and when you tried sewing your usual thickness, the cranks bound up. There should be an adjustment on the rear of the machine where a shaft sticks out and connects to the cranks that move the feet. This shaft would be adjustable up and down by loosening a large screw on the joining knuckle on the back. You can set the alternating height to only what you need, and which avoids a lock up. I remember this screw on the last forum post I made about this issue almost a year ago, once I’m home I’ll take photos and turn the screw, I’m sure that’ll fix it as it did in the past. I’ll make sure to document it all so this thread can be saved for future references. Quote
Members Lugubrious Posted December 6, 2024 Author Members Report Posted December 6, 2024 14 hours ago, Wizcrafts said: Oil inside the head. Cover all of the crank shafts and rods that move. This might loosen it up. Lower the feet and see if it moves freely with the feet down all the way. It could be that something slipped and when you tried sewing your usual thickness, the cranks bound up. There should be an adjustment on the rear of the machine where a shaft sticks out and connects to the cranks that move the feet. This shaft would be adjustable up and down by loosening a large screw on the joining knuckle on the back. You can set the alternating height to only what you need, and which avoids a lock up. Turning the screw on the knuckle got the walking foot to work properly again. The spring hasn’t let up, is there any way I can get the walking foot to lift more? So far this is the highest I’m able to get it Quote
Members Lugubrious Posted December 6, 2024 Author Members Report Posted December 6, 2024 2 minutes ago, Lugubrious said: Turning the screw on the knuckle got the walking foot to work properly again. The spring hasn’t let up, is there any way I can get the walking foot to lift more? So far this is the highest I’m able to get it It can sew and feed 2 layers but once I get to 3 layers it won’t walk the leather at all Quote
Members Constabulary Posted December 6, 2024 Members Report Posted December 6, 2024 read the manual for your machine there should be a section for how to increase the height of lift for the lifting and vibrating presser foot Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
