Members Sawyer Posted December 14, 2007 Members Report Posted December 14, 2007 How do you stop the leather from puckering around the corners when putting the leather on the seat pan? Quote
Guest Posted December 14, 2007 Report Posted December 14, 2007 (edited) Sawyer, I'm assuming you are doing the wet mold technique that Beeza uses. Try looking in this article motorcycle seat the beeza way It is in the How do I do that section Dave Theobald Edited December 14, 2007 by David Quote
Members Sawyer Posted December 15, 2007 Author Members Report Posted December 15, 2007 i'm doing this dry. i'm i to cut around the radial area ? the Beeza article did not show what i need to know Quote
Roger Posted December 15, 2007 Report Posted December 15, 2007 can you post a pic of the problem? Quote
Ambassador Beaverslayer Posted December 15, 2007 Ambassador Report Posted December 15, 2007 Sawyer, to be able to stretch the leather around the pan without leaving wrinckles or puckers, you have to wet the leather first. This will allow the leather to form around the edge of the pan. Trying to pull dry leather tightly around the pan is going to be very hard, and will result in the problems you're having. Ken Quote
Members Sawyer Posted December 16, 2007 Author Members Report Posted December 16, 2007 thank you very much for the info, i''ll try taht. How wet should the leather be? Quote
Roger Posted December 16, 2007 Report Posted December 16, 2007 i use a spray bottle as shown in my "how to". just wet both sides. try not to wet your tooling too much if you can help it Quote
