Members ThomasA Posted January 6, 2025 Members Report Posted January 6, 2025 Hi all, I got this felt pad and a loose oil wick with the machine. I haven't thought about it, but then I stumbled across this parts listing that has a match. However, I cannot find a good place on the rock frame assembly where it seems to fit. Someone who knows how is mounted? Quote
Members ThomasA Posted January 15, 2025 Author Members Report Posted January 15, 2025 OK no answer, but I found this post! Quote
Members shoepatcher Posted January 17, 2025 Members Report Posted January 17, 2025 wash both felts out with mineral spirts to clean them. The long worn wick fits under the staple on the flat felt. That sits on top of the rock frame that part #44 fits into. glenn Quote
Members ThomasA Posted January 20, 2025 Author Members Report Posted January 20, 2025 Ah, thank you Glenn! OK, so it's supposed to get squeezed into the slot where the block rides? Or how can it "sit" on top of it? It seems like I will have to remove the rockframe to replace the felt. I haven't done that yet. Maybe it will be obvious when I see it from the other side. thomas Quote
