Members SaraJ Posted February 1, 2025 Members Report Posted February 1, 2025 I have a Singer 153K103. Sometimes when sewing, the needle changes position and hits the feed dog. When it does i have to adjust the needle in place by pushing the needle bar. After doing that it stays in place for a while but suddenly it hits the feed dog again... Why? Quote
kgg Posted February 1, 2025 Report Posted February 1, 2025 1 hour ago, SaraJ said: I have a Singer 153K103. Sometimes when sewing, the needle changes position and hits the feed dog. A couple of questions: i) What size of thread are you using? ii) What size of needle are you using? iii) how thick of material are you trying to sew? iv) Does it happen on straight runs or when doing curves? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members SaraJ Posted February 2, 2025 Author Members Report Posted February 2, 2025 Thread: Serafil 20 Needle: 135x17 180/24 Material: 1 - 5 mm. Happens both on straight runs and in curves. No difference between thickness in materials. /Sara Quote
Moderator Wizcrafts Posted February 2, 2025 Moderator Report Posted February 2, 2025 @SaraJ There is a possible explanation for your sideways needle bar motion. That could be caused by a loose or misadjusted L shaped bracket at the bottom of the head, on the left end. This bracket secures the needle bar, inside (aka: alternating/vibrating) foot bar and presser bar, keeping them aligned laterally. Here are two photos showing the wide and close=up view of the parts. My machine is a flatbed 111, but the mechanism is the same on your Singer 153. The screw secures the bracket. The hole in the bracket is wider than the screw. This lets it move to the right and left to set the clearance to a minimum, or maximum, as desired by the user. Try tightening it while pushing it to the right. But, don't let it bind the shafts. They must move freely, but without noticeably shifting to the right or left. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
