Leather Machine -Master Tool Deluxe EZ Edge Strap Beveler
OPEN TO OFFERS. Purchased from Weaver Leather for $1350.00 three years ago. Went a different direction. Used under 10 times. Selling to recoup cost. Convenient leather strap beveler machine gives you the ability to edge all four edges of your strap at once for time savings and reduced labor costsWith 12 cutting blades (6 on each side), the blades can be rotated and switched to the opposite side so you don't need to re-sharpen as frequentlyBottom blades can be dropped down if you want to edge the top two edges onlyHand-operated, thoughtfully-designed machine will not reduce strap widthAccommodates 1/2" to 3" strap widthsRotating the blades and switching the side the roll is on helps reduce the need to sharpen as frequentlyStandard set-up includes a set of four #2 bladesAdditional blades sold separately in sets of two, available in size 0, 1, 2, or 3Instructions includedHandcrafted in the USA
Please read the marketplace rules and conform.  You must provide a price, and any information or restrictions on shipping.  Failure to conform may result in your ad being blocked.
See the marketplace rules here  https://leatherworker.net/forum/forum/70-announcements/
