Members mcmuck Posted Monday at 04:37 PM Members Report Posted Monday at 04:37 PM Hi Folks! I've been leather working for about 5 years now, I'm retired, so it's a spare time thing. When I started I bought a used "serviced" Juki as it was the most copied machine out there. As it turned out it was well used and poorly serviced. My back ground is mechanics so I set about making it right. I was able to make it better but definetly not perfect, every 6 months or so I would take another run at it : ) I replaced the timing belt as it looked like it was going to fall off, a ton of chowdered and missing fastners, installed a lot of the missing oiling system etc. I've watched Uwe's making a stitch video about a thousand times and I've managed to make progress. There are two things I can't sort out. In the service manual, engineering guide the needle bar length for hook timing is listed as 59mm +- I cannot set mine there, in order for the needle to be in the correct location I have to set it at 50mm. At first I thought I was doing something wrong etc but the manual is clear about where to measure so I'm confused about that. The second thing is If I center the needle in the feed dog longitudinally the throat plate is 3mm from contacting the body of the machine. I have gone through the manual start to finish but there is no way that I see to move the needle bar assy toward the rear. If someone with experience with this machine could point me in the right direction I'd appreciate it. I replaced the needle bar with a new one I ordered from Juki (along with a bunch of other things) and it came identical to the one that was in my machine. This machine has had numerous sketchy repairs over time but the actual linkage and mechanism appears to be sound and original. I've identified and repaired most of them but these two things elude me : ) Stay Safe! Oh and if this the wrong place for this I'm sorry, go ahead and move it to where it should be. Kelly McLaughlin Medicine Hat Alberta Canada Quote
Members shoepatcher Posted Monday at 10:04 PM Members Report Posted Monday at 10:04 PM Pics of the needle bar and the throat plate alignment. glenn Quote
